There is the thing... Terramar (Black Edition)
Maverick
Hello,
I wanted to introduce our Terramar.
After several weeks of research, considerations, and weighing options, it turned out to be the Terramar with a 2L 204 hp engine, not a Leon or a hybrid.
Due to my annual mileage and the negative aspects of hybrid technology, I opted for the small petrol engine. 204 hp should be sufficient; the 265 hp version has too high fuel consumption for me. Especially since it is already higher than my previous 184 hp diesel 🙈🤣
Once the decision was clear, I searched for the desired equipment (the only thing missing is the 360-degree camera) because a waiting time of at least 6 months was logistically not possible for us.
It has finally been in our possession for 3 weeks, and I am already looking forward to the end of the break-in phase. 😎
After initial software and user issues, I am now very satisfied with the Terramar. Initially, it was, of course, a huge adjustment from a 2017 Octavia RS Combi. But by now, you get used to it, and almost all settings have been made/adjusted.
Only a few minor things bother me. Among other things:
- that it doesn't coast properly
- the mirror heating seems not to work
- when changing songs, there is an occasional crackle in the Sennheiser sound system via Spotify Android Auto
- light animation only works sporadically
Here is the equipment it has:
- Dinamica Comfort
- 20" Hadron
- Edge
- Digital Drive
- Sennheiser
- Electric towbar
- Intelligent Drive Package L
- Pure Performance (Matrix, DCC)
So far still stock, but some changes are already planned.
Definitely lower, 21 or 22 inches, all gray accents in black (let's see if painting, wrapping, or using the Tribe Edition elements). Maybe a lip, rear diffuser, "side skirts." Whether that will happen this year, I don't know yet. Other things are on the agenda first 🤣
Erstmal herzlichen Glückwunsch zu dem neuen Gefährt.👍 Aber eine Frage: Was meinst Du mit "negativen Eigenschaften der Hybrid-Technik"?
Vielen dank.
Zum einen das der KALTE Benziner wenn er "angefordert" wird zB bei Last von jetzt auf gleich mit hoher Drehzahl gestartet wird.
Kein Öldruck da, nicht warm gefahren.
Das wird definitiv einen frühen Tod bedeuten, bzw sehr hohen Verschleiß.
Und da ich im Jahr ca 25000 km fahre und den Wagen in frühstens 5 Jahren verkaufe, gehe ich davon aus das der Marktwert bis dahin ziemlich im Keller sein wird.
Wie Fit der Akku bis dahin noch sein wird bleibt auch ein Rätsel.
Die theoretische elektrische Reichweite von 120 km, welche in Wahrheit eher bei 80 km liegen soll passt ebenfalls nicht in mein Fahrprofil (50 km täglicher Arbeitsweg 50% davon Nachts).
Das ist keine generelle Aussage, sondern nur meine Sichtweise.
Ich sage nicht das die Hybridtechnik schlecht ist, nur halt für mein Fahrprofil in meinen Augen eher ungeeignet/unwirtschaftlich ist.
Ja, bei Deinem Fahrprofil passt das dann wohl nicht. Ist bei mir genau umgekehrt. Den Verbrenner brauche ich so gut wie nie, da ich rein elektrisch zwischen meinem Zuhause und meiner Firma pendele. Für weitere Strecken nutzen wir den Cupra kaum, da wir noch ein paar andere Fahrzeuge zuhause im Bestand haben.
@Killboy
I see it exactly the same way as you do. And the early failure of petrol engines in eHybrids has not yet been observed, and eHybrids have been on the market for quite some time now.
I think so too @Killboy, since with hybrids the battery is often also discharged, the cells do not "age" as much as with pure electric vehicles, but I am not an expert here and it is only a guess, before I get punished now 😝 :LOL: 🙈
Only the number of cycles is relevant here.
If the hybrid often runs on battery or almost exclusively, then naturally it ages faster than one three times the size in a BEV.
And it is important to know that if the battery is dead, it CAN happen that the car no longer runs on the combustion engine alone and the battery must be replaced.
There was recently an article on one of the car magazine websites about this (I don’t remember where), concerning hybrids about 10 years old from German manufacturers like BMW, where you quickly approach the edge of economic total loss.
well, with the older ones...
in the new cars there are several mechanisms installed to protect the battery. I have that with my home energy storage system too....
I personally always find the topic of aging difficult. In theory, yes, but no car will last as long as the cycles reach the maximum.
A mobile phone is also regularly charged, often more than the car (at least in my case), and doesn't break down after two years either.
But basically, you're right!
Ne defekt nicht, aber das Handy muß dann schon 2 x mal Tag geladen werden 😉, also ist die Akkukapazität sehr schlecht.
Wie gesagt das ist meine Meinung, ich habe mir da lange Gedanken drüber gemacht und mir ist ,bei 50 K, das Risko einfach zu groß, deswegen habe ich mich für einen Benziner entschieden. 🤷‍♂️
BtW das hier hier mein Vorstellungthread und kein Hybrid Diskussionsthread 😜🤣🤣🤣
The question would be, when does the battery likely die (years)? And to my knowledge, it is cheaper for the battery to theoretically plug it in daily even with a hybrid. Even if it still has 30-60%. And the durability of combustion engines is significantly higher than that of normal engines. The manufacturers have already taken this consideration into account. Otherwise, it would be an early death. Apart from that, I haven't heard/read anything about the battery or motor dying yet.
Gerade passend zum Thema, wobei ich es trotzdem nicht ganz so dramatisch sehe:
Bin trotzdem froh, dass ich mir einen Plugin-Hybriden bestellt habe und bekomme den hoffentlich auch endlich im Juni.
I have now seen that too. However, in the current Formentor LFP (Lithium) battery, they are indeed more stable. And there is also an 8-year warranty and/or 160,000 km. That is more than enough. But this is also very informative.
Sry Leute, wollte jetzt auch hier nicht die Dicke Diskussion lostreten, Es ist ja auch vollkommen in Ordnung, dass jeder sich noch entscheiden kann, was er fahren möchte.
Habe auch mal überlegt, bei meinem mal den SoC von der Batterie zu ermitteln, find es aber nur immer noch recht teuer was die dafür verlangen....
Ich hab noch nen altes iPhone 8 Plus, das funktioniert auch noch, solange man den Akku nicht fordert. Dann kann man aber zuschauen, wie die Prozente runterzählen, unter Last.
Last beim Auto = Beschleunigen...
Direkt kaputtgehen werden die Akkus eher nicht, aber langsam immer "kleiner" werden.
Deswegen haben die das bei meinem Heimspeicher anders gelöst, um die gekaufte Kapazität zu garantieren, hat der Akku mehr Kapazität, die aber nach und nach freigegeben wird, wenn der Akku Schwächer wird. So Könnte ich es mir beim Auto auch vorstellen, denn die geben ja eine Garantie von 8 Jahren, dass der Akku nicht unter 80% fällt in der Zeit.
Ihr alle habt Recht, und es ist ein Thema mit dem schwächer werden, aber für mich persönlich nicht so dramatisch, wie es manche glauben, aber ich sammle nun auch meine ersten Erfahrungen und werde sehen, ob sich der mehr Preis für den Hybrid gelohnt hat, oder nicht.... 🙈 Habe vom Freundeskreis auch diverses über meine Entscheidung zu hören bekommen, deswegen kann ich immer nur sagen, ich mache nun meine Erfahrung und werde am Ende wissen, ob es gut oder schlecht war.
