Turn off all exterior lights while stationary?
franzpg
One-Post-Wonder
Hello everyone,
I drive the Cupra Leon ST 1.5 e-Hybrid (Facelift 2025, 272 PS) and I'm facing a puzzle: How do I completely turn off the exterior lights with the ignition on?
At the drive-in cinema, I wanted to keep the ignition on for the climate/heating, but I can't deactivate the lights using the touchpad on the left (Auto, Low Beam, Parking Light). The parking light stays on continuously. I've searched high and low in the settings of the infotainment system. Unfortunately, the Cupra Concierge Service on the phone was also stumped.
Dieser Artikel hier That didn't help me. There is no "off" in the modes. It only switches in a circle between the modes written above.
Is there any trick to make the car completely dark when "ignition on"?
Thanks for your tips!
Mit vcds gibt es die Möglichkeit die Funktion (Schaltfläche) freizuschalten. Sobald aber Cupra updated ist diese Funktion wieder weg.
Wenn die Zündung / Motor an ist, dürfte schon mal das Tagfahrlicht (nicht zu verwechseln mit dem Abblendlicht) permanent aktiviert sein. Ist das nicht sogar Vorschrift hierzulande?
Hab mal ChatGPT gefragt (Plus).
Wie @Fiestameetsmini geschrieben hat nur mit einer Kodierung / VCDS möglich.
so with the PHEV you don’t need to have the ignition on, just turn on the parking heater?! That’s how I do it at least 🤷‍♂️
