Update News
Ja korrekt. Also nachdem sich der Tacho komplett aufgebaut hat, dann starte ich. Wenn die Lichter aber bereits schon länger aus sind, z.B. wenn ich den Kofferraum erst noch belade, dann kommt die Fehlermeldung ebenfalls nicht.
Now for a (stupid) question.
How do you start the car? Unlock the car > get in > and start immediately?
I do it like this and haven’t had the problem (touch wood) yet.
Unlock the car > get in > ignition on > then wait 2-3 seconds > and then start.
For me, ignition on and starting is one process because I always keep my foot on the brake straight away.
I'm just making sure not to get in with my foot on the brake...
So door open, get in, door close, buckle up, check if the speedometer is awake, brake + button
But why should I have to press the start button twice when it works the first time? I never had problems with this method, neither with the pre-facelift nor with the Ateca or Terramar.
I didn't say that, the speedometer wakes up even without pressing the button...
I only press the brake when I also press the button.
Oh right, yes, I do that too. But I think with the pre-facelift models the speedometer usually doesn’t manage to be "awake" that quickly (though I haven’t really paid attention to that), but everything still worked without any problems.
At some point, I started pressing the ignition first and then starting the car after a few seconds. I once picked up somewhere that this is supposedly better for the car, the oil pressure, and the systems. Whether that’s really true or just nonsense > no idea. Unfortunately, I don’t have the necessary expertise for that.
It definitely can’t harm the car, and it makes me feel a little bit more “comfortable” with the car. And I still have those 2–4 seconds to spare in today’s stress-filled daily life. 😅😂
By "starting the car," do you mean engaging the gear and driving off? Because turning on the ignition (without pressing the brake) only starts the infotainment, which in turn cannot affect the oil pressure.
No, by starting I do mean actually starting the engine.
Then I must have misunderstood. I was under the impression that I had heard that turning on the ignition also activates the oil pressure sensor (no idea if that’s correct). With my previous car (Golf 7.5 R), definitely more happened under the bonnet than just the infotainment system.
Reactions: ekm
No, I misunderstood that the sensors might already be activated and then "asleep" at the start, that could well be the case, I can neither confirm nor rule it out. By infotainment, I meant that only the electronics are started.
So, for everyone who is interested, there is finally a new update here, I will report in the coming days whether I notice a difference….
Edit: I can already say that the app loads significantly faster than before!!!
Version 2.4.1 from 10/30/2024 is currently available in the Playstore.
For iOS devices, version 2.5.0 has been released today.
Dann wird es wohl bald im Playstore auch auftauchen
Da wäre ich mir nicht sicher, ob die Versionsnummer hier in beiden App-Stores gleich ist.
Im Apple-App-Store gab es keine Version 2.4.1 sondern nur die 2.4.0
Also meine App hat sich heute Nacht aktualisiert.
Android
Version: 2.5.0
Schaut minimal anders aus und reagiert etwas schneller.
s see what happens today throughout the day and how the
Keine Ahnung ob das Stoßweise ausgerollt wird.
Habe Android 13 drauf, mit nen S20 Ultra. 🤷‍♂️
Android 14 bei einem S22Ultra
komisch ist es schon, dass es hier Unterschiede im Playstore für Android Handys gibt.
*achselzucken*
