Various topics on the systems
Cupra2025
Hello everyone,
I got the Formentor MJ 2025 yesterday and I didn't expect anything different, that the software is very stubborn (VW...). I have the following questions for you:
- I have, among other things, the Matrix LED from the Pure Performance package. Unfortunately, the high beam assistant (A) resets to off every time I start the car, even though I had it on last time.
- The driving profile resets to "Comfort" every time I start the car, even though "Performance" or "Individual" was previously selected.
- The kick function for the boot is as bad as expected - or am I doing something wrong here?
- Start/Stop can only be temporarily deactivated through the menu? Normally, it was the case that when S is engaged as the gear, the Start/Stop is also deactivated.
- *laughs* There really isn't an oil dipstick to measure in this thing?
Yes, I am the main user and it already pulled updates during the drive home yesterday.
A nice car, but you can really feel the Seat or VW influence in the processing, painting, panel gaps, and materials.
Thank you very much and safe travels to everyone!
1. Are the conditions for activation met? Only grayed-out A visible?
2. Correct, the vehicle always starts in Comfort mode.
3. The kick function is actually very reliable when done correctly. Kick in the center and then take a step back. The key must be behind the vehicle.
4. Yes, start/stop can only be temporarily deactivated. EU regulation.
5. No oil dipstick as far as I know, only digital display.
Vielen Dank für erste schnelle Antwort.
Das mit dem Fahrmodus ist für mich komplett unverständlich. Die Gedankengänge muss man ich nicht verstehen. Letzter Modus und fertig.
Zum Fernlicht: Es ist tagsüber, hell, mache den Fernlicht Assistent an, schalte das Fzg aus, starte wieder und das weiße Symbol dafür ist wieder verschwunden.
Zum Öl: habe kein Menüpunkt dafür. Eben mal unter der Motorhaube geschaut und es ist ein Stab vorhanden xD.
Hab's eben 20 mal mit einem Kick probiert, gestern ging es mal. Auto ist nicht verriegelt, schlüssel habe ich in der Hosentasche. Mittig tief rein, nur kurz, etwas links oder rechts... Nichts. Habe mich mal unter das Auto gelegt aber keinen wirklichen Anhaltspunkt für einen Sensor gefunden. Kann es sein, dass es bei Modellen mit AHK schlechter funktioniert?
Bei mir klappt es immer, wenn ich dem Auto mittig in den Hintern trete😅 dann ein Schritt zurück geh.
So funktioniert es immer
Wichtig ist der Schritt zurück. Die hinteren Ultraschallsensoren registrieren Hindernisse und verhindern das Öffnen der Klappe. Du würdest sie sonst auch ins Gesicht bekommen.
Fla resettet sich, genau wie alle anderen Systeme. Leider.
Naja einmal ging's eben.... Easy Open und Keyless aktiv.
Andere Frage: heute morgen kam die Meldung 12V Batterie schwach. Bin dann 20 Minuten gefahren und abgestellt. Eben wegen dem EasyOpen geschaut und die Meldung kam wieder. Gestern bin ich ca 1.45Std vom Autohaus ä nach Hause gefahren. Hab schon über ein paar Probleme mit der Batterie gelesen. Ist übrigens ein Diesel. Selber laden der Batterie wird ja "strengstens untersagt" seitens cupra. Hab das CTEK one - sollte damit ja einwandfrei klappen aber setzte mich deswegen nicht in die Nesseln. Was mit mein Nachbar vorhin gesagt hatte: Vorder- und Rücklicht hat die Nacht über, warum auch immer, gebrannt.
Edit: muss das Auto entriegelt sein, damit die Kofferraumklappe mit dem Kick aufgeht oder geht's auch wenn's verriegelt und der Schlüssel in der Tasche ist?
Warum nicht selber laden? Ist doch kein hybrid. Ein Kabel auf den Pluspol und eines an die Ladeklemme am Blech oberhalb der Batterie. Schau, ob du AGM oder EFB hast und stell das Ladegerät entsprechend ein. Über Nacht durchlaufen lassen und gut.
Ist auch nicht auszuschliessen, dass die Batterie defekt sein könnte. Hatte ich in 100% der Autos seit 2010 (ok, das waren nur 2, Scirocco und Skoda Karoq).
Deswegen mal laden und beobachten!
Habs CTEK angeklemmt. Hat die Batterie erkannt und lädt. Welche Batterie es ist lässt sich nicht erkennen. Ist mein erstes Fahrzeug wo die selbstständige Ladung untersagt wird - schon etwas lächerlich aber so bekommt man auch Kunden in die Werkstätten. Ich kann euch gerne mit dem Batterie Thema auf dem Laufenden halten. Danke noch mal an alle. Werde cupra eine Mail wegen den Assistenten schreiben, mal schauen welche vorgefertigte Antwort ich bekomme.
Cupra verbaut EFB+ 12V Batterien.
Edit: Hier im Forum gab es auch mal nen Bild. Gefunden ✔️
Zwar vom Hybrid, sollte aber keinen Unterschied machen.
Selbst bei meinem PlugInHybrid habe ich die 12V-Batterie schon geladen (warum auch nicht?), bevor ich sie dann gegen eine Neue getauscht habe.
Habe AHK und der Kick zum Öffnen funktioniert trotzdem prima. Auch wenn das Fahrzeug abgeschlossen ist. Schlüssel muss aber beim Mann/Frau sein damit es rut. Kurzer Kick nur mit dem linken Fuß. Dann geht er auf.
Update zur Batterie: Samstag und Sonntag geladen, auf 100%. Bisher keine Meldung mehr. Der Wagen steht sehr nah an der Haustür, ich habe die Vermutung, dass das Proximity Light dadurch noch eine minimale Verbindung zum Schlüssel erkannt hat und daher an blieb. Habe die Funktion erstmal deaktiviert.
Zum Kick: es klappt hin und wieder aber verlässlich ist anders.
Bei mir klappt es zu 99%.
Mit dem Fernlichtassistent ist blöd, aber der resettet sich immer mit allen anderen EU Spielereien.
Gerade da es Matrix ist und cupra eine Blendung anderer ausschließt sollte das Standardmäßig aktiviert sein. Wird es aber wohl nie werden.
Einfach nur die Härte... Haustür Start/Schrott bleibt an, Lane Assist und die KM/H Warnschwelle ist immer wieder auf Standard statt meinen gewünschten 5km/h und der Modus auch immer Komfort. Egal, soweit läuft dann jetzt alles. Danke euch allen!
Da kann aber cupra nichts für, das ist seit 2024 oder 2025 eine EU Vorgabe die jeder Neuwagen erfüllen muss. Die einzige nützliche davon ist die verpflichtende eSIM und der Notrufassistent.
Leben müssen wir aber leider mit allen.
Ich weiß...die EU Regulierungsmaschine. Aber man kann es dem Fahrer mit Knöpfen einfacher machen - ein Druck und die schwarze Magie hat ein Ende. 😂
Ich denke dass das mit physischen Tasten nicht mehr erlaubt ist. Deswegen kannst du dir aber frei verfügbare shortcuts legen. Einfach auf dem Mediasystem wie auch beim Handy einmal vom oberen Rand nach unten wischen, dort sind dann sowohl Kacheln für die Geschwindigkeitswarnung als auch für start Stop. Beide Assistenten zusammen sind in einer Sekunde deaktiviert 😇
Einfach über den Shortcut einstellen, da braucht es keine physische Taste. Ist ja sogar dort schon hinterlegt im „Werkszustand“
Für Start/ Stop existiert ja der physische Schalter.
An dem Rest änderst du auch in anderen Fahrzeugen nichts.
May be we can as forum community collect the amount of people which like to keep last drive profile. Then we can share this with CUPRA factory to change.
This is regulated by the European government. They have no space to change it as they want. Because of the Technical Inspection Association ( TÜV in germany, Austria etc. And APK in the Netherlands ) it always needs to be on stock after a restart to follow the laws for the maximum air pollution.
When it would always start I cupra you won't get the degree. Especially in Germany the "AU - Abgasuntersuchung" idk if there is something similar in NL
