VZ Hybrid rear brakes uneven wear
That's right, it has been pouring down like buckets here for hours, the air is humid and it hasn't been moved. I'll take the drive home easy and keep an eye on it. Thank you all!
poured down like buckets
possibly combined with salty air.
To be honest, I haven't seen such discs before. As already mentioned, "the braking effect is likely to be low at the moment" and "drive cautiously." Therefore, it might be better to "brake clean" the discs and pads as a precaution before the return trip.
I'm more inclined to @SirOssyThat looks normal for the weather conditions. It shouldn't have been any different for the other cars that were nearby either.
The problem with hybrids has been known for years. What do the brake discs look like on purely electric vehicles?
For the rear brakes, VW simply installs drum brakes on its fully electric vehicles, as seen in the ID3 and ID4 - even in the GTX models. Other manufacturers, such as BMW, do use disc brakes at the rear, but they have established a system that occasionally (without the driver noticing) lightly applies the pads to the discs while driving, ensuring they are always clean. Our iX3 company car does this, for example.
For some, I know it would definitely just be a software solution for Cupra to solve this problem. Hybrid and fully electric. I would see it as a defect in the vehicle, precisely for this reason.
Indeed, the drive home mostly polished the brake discs smooth. Unfortunately, I also have an ugly edge on the rear ones. I've now set the recuperation to "Weak." It's a shame that Cupra can't manage this better; a software solution like BMW's should be relatively easy to implement. They don't need to redesign the whole car.
One could now say, "It's just a Cupra and not a BMW," but that would be too simple, wouldn't it?
@rhaen That's exactly my problem. It won't be able to brake anymore. After months of complaining and negotiating, I finally received a voucher from customer service as a goodwill gesture so that I can have the discs replaced. The CUPRA technicians are extremely rude towards my dealer and only write nonsensical responses that have little to do with the damage.
It might be good to know how many e-Hybrid vehicles are affected here in the Forum. Would it be possible to start a survey? I believe that Cupra either used inferior materials or that the car does not correctly or hardly uses the rear brake. I keep trying to brake, but our leased vehicle, a Jeep Avenger electric, looks much better on the discs and it recuperates significantly more.
I will have the brakes and discs replaced in 2 weeks, and if it happens again, something is wrong with the construction of the Leon ST VZ e-Hybrid FL.
Regards,
Ossy71
In my Leon PHEV pre-facelift, the now 6-year-old rear windows, as already mentioned, also look very modest. However, I still passed the TÜV last year without any issues. Before the next TÜV in 2027, I will completely renew the stuff in the back.
I wouldn't even know how else to brake. I usually have a small child with me, so sudden full stops would be extremely unpopular :) Especially since we have almost constant speed limits of 30 or 40, you inevitably drive more relaxed and put even less strain on the brakes.
You can also have the windows re-tinted. It probably means something similar? They have enough thickness.
@Killboy Who does something like that? Do you have a provider? However, Cupra should acknowledge the problem, get it under control, and offer a solution.
I once had a Toyota Avensis years ago. After 40,000 kilometers, the windows started making noises, and I was on vacation in southern Germany. I dropped the car off at the nearest Toyota workshop, and after 4 hours of sightseeing, I picked it up again. The explanation was just that there were no windows in stock, so they had them reworked. Everything was great afterwards.
40,000 km would be a dream. For me, it started after 3 months and got worse and worse. At that point, my Cupra had only 4,000-6,000 km on the clock. It seems Cupra really produced some rubbish. As a layperson, I have the question, why can't the brake pads be lightly applied at the back when braking? Isn't that possible via a software update?
I will bring up the issue with the dealer next week. Unfortunately, I had to make another appointment because the control unit for the roof/interior lighting/emergency call is completely dead (located in the middle directly behind the rearview mirror). It's good that there is at least a TPI regarding the window issue, so they can't just brush it off.
@rhaen The control panel has also been replaced for me; I was lucky to have the problem only rarely, but I made a video right away and thus had it replaced by Cupra without any issues.
It looks the same for me, but I don't care at all. The main thing is that it brakes well, and it does.
@Michel
Exactly. On the brake test bench, mine achieved top values despite the poor appearance. That's why it easily passed the TÜV last year.
