VZ Hybrid rear brakes uneven wear
I have now had both (brake pads and brake discs) replaced for a few weeks. It's starting again. Once again at my CUPRA service partner. They have looked at it again and I should test it once more. However, I have little hope; I was at a Raval test drive today and in the dealer's yard, there were several CUPRA Leon STs, and you wouldn't believe it, all of them had terrible-looking rear brake discs. With the Skoda Octavia or Superb estates, everything was super evenly silver and no rust. It seems to be an exclusive CUPRA Leon ST problem and not just with the e-HYBRID. I only drive with weak recuperation now and let myself roll down the hill in neutral and brake hard. All without success. We should collect the problems and report them to an automotive magazine so that CUPRA feels more pressure here. It's also strange that the discs are free in some places and only at the bottom and top do rusty rings form, as if the pads were not making contact evenly.
This is most likely due to poorly functioning guide pins of the floating calipers at the rear.
Disassemble, clean, grease well (assembly grease), reassemble.
Has no one affected tried this yet?
Also check whether the handbrake/parking brake mechanism at the brake caliper is working properly; if it is rarely used, it can sometimes get stuck (if it is supposed to be operated by cable).
This is exactly the same error pattern as with our Fiesta, where the mentioned procedure helped. However, it only worked after a local workshop (acquaintance) did a thorough job.
Expressing with the mention of the panoramic roof???
As far as I have heard next door (our ROC does not have a pano), there are a few "minor issues," such as water ingress (the drains are clogged, which is of course also a matter of ongoing maintenance, or the drain hose has slipped off). Partially, the panos are also "installed under tension," so that it or the roller creaks or does not close. If I remember correctly, one or the other pano was completely replaced (under warranty/guarantee).
@Ice-Mark What happened to your brake discs? Were they replaced due to the TPI? I think I read somewhere that someone got new discs, but I can't find it in this thread. Next door, someone bought a 3-year-old ROC (14,000 km). The discs need to be replaced (€800). Of course, I've already cited the TPI, but if someone had their discs replaced due to the TPI, that would be even better for the argument. Thank you.
My discs and pads were replaced at the back, but they already look just as bad again.
look just as :poop: as before
which is of course suboptimal and honestly surprises me a bit. For the ROC, there is, for example, a TPI "mooing brake pads" (that's actually what it's called), where different pads with a different part number (ending in "J") are installed. In your case, I would recommend complaining again regarding the disc TPI and asking if other discs could be installed. Perhaps the "defective" parts are just from a certain batch or from a specific supplier.
but he brakes and that is important.
yes, sure. But let's be honest, something is definitely wrong with the brake discs. I can't judge what (charge, manufacturer, cost-saving measure > alloy) causes the discs to look so rusty in places. My discs (year of manufacture 18) certainly don't look like that. We already know the general phrases "state of the art" and "that's normal." My saying is always: "if that's normal (state of the art), then all discs that don't rust are not 'state of the art'." Our ROC passed the 3rd inspection/emission test on Monday without any noticeable defects. I wouldn't want to know what the inspector would have said about such discs.
Hello, I still have the problem. TPI was done, yet the rust rings are still at the back. After months of negotiations, I received vouchers from customer service and had everything redone at the back (not under warranty). However, when driving normally in the fall, there’s no chance of keeping the discs rust-free. Yet it’s always just rings. What I don’t understand is that I have to repeatedly brake hard in neutral every week, for no reason. Then I can somewhat keep the rust at bay. For that, I have to replace the expensive Brembo brakes at the front sooner. So it's a win-win for Cupra. I have been driving cars for almost 40 years and have also driven VW for a long time, and my normal brisk driving style was enough to keep the brake discs clean. I am extremely frustrated with this. Attached are the discs left and right, after a week of normal driving. Regards, SirOssy
... I wouldn't want to know what the inspector would have said about such discs.
If the inspector has any sense and the braking values are fine, then he won't say anything, as it's just a cosmetic defect. My Cupra passed the TÜV last year without any issues with the worn discs. The braking values were excellent, but the discs at the back did look pretty shabby.
@Gand-Alf I spoke to my workshop about the TPI, but we decided against it because we don't see the point in just renewing the pads. I recently had the first service, and there is also a note to keep an eye on the rear brakes... I will have the TÜV in a year and will present it as is; let's see what they say. Currently, I'm driving with low recuperation, and the rears look a bit better, but unfortunately, there is still a rim left....
@csxsi Fortunately, it doesn't look that bad for me :eek:
