Windshield interior frosted
FCE1982
Hello everyone,
I have had the current Cupra Leon facelift for just over a week. Overall, I am very satisfied with the car. However, a major downside is the windscreen and rear window freezing from the inside during stronger frost at night. The Cupra dealer said this was probably due to residual moisture inside the car after the vehicle was detailed before handover to the customer. After more than a week, this no longer seems plausible to me. The valves and seals have already been checked by the dealer following my complaint. Apparently, that is not the cause. Does anyone have any other ideas what might be causing this and what can be done about it?
Thank you very much
To me, the dealer's statement sounds plausible after one week. You should also mention your environment, for example, if there is currently high humidity in the outside air in your region and you haven't driven much in a warmed-up car, then the humidity inside the vehicle could still be high enough for the window to fog up on the inside.
Do you perhaps have a humidity meter that you could place in the car and take several measurements with?
Try to document your tests and measurements thoroughly so that you can potentially use them as evidence of a defect when dealing with the dealer.
Hello, thanks for your reply.
The humidity is actually quite high at the moment. You can also see that from the frost. The idea of a humidity meter for the car is a good one. The air conditioning runs regularly on longer journeys. I would be interested to know if anyone else has the same problem or if I’m just unlucky :) The Cupra dealer didn’t seem to be aware of the problem; they gave a rather overwhelmed impression…
That is probably due to the remaining moisture inside the car
in my opinion, that is correct. Whether the moisture is residual dampness from the detailing is questionable.
whether someone else has the same problem
yes, just recently a convertible... Humidity is hopefully always present. The warmer the air, the more moisture it can hold. The temperature at which the humidity condenses is correspondingly high. Suppose you have wet rainwear, an umbrella, etc. in the car; these items, like the passengers, also release moisture. The warm air can absorb it as long as it is not saturated, as can the upholstery, by the way. All completely normal. Now you turn off the car and the climate control. The air inside and on the windows cools down. Eventually, the dew point (the temperature at which the air has a relative humidity of 100%) is reached, the humidity condenses, and settles on the windows. If the surface temperature is below zero, it freezes.
The simplest measure would be to remove rainwear etc. from the car and ventilate it well for a while
Example:
Air temperature: 20 °C, relative humidity: 70%, water vapour content: 12.1 g/m³
If the air cools from 20 °C to 0 °C, it is saturated at 4.8 g/m³.
The difference of 7.3 g/m³ condenses out.
At low temperatures near or below freezing, the Cupra will probably also switch off the compressor. At that point, it no longer makes sense to cool the air down first, especially since the system risks icing up. However, this also means no drying takes place. As a rule, pure heating mode is switched on at the latest when the outside temperature reaches 5°C.
The only solution then is to heat thoroughly and ventilate well to get the moisture out of the vehicle again. Short trips, wet clothes, and shoes are rather counterproductive in this case. Only warm air can absorb moisture, but it must then be expelled and replaced by cold, and therefore dry, air. That’s why you should never ventilate a cellar in summer.
Pure physics, as Gand-Alf also already writes.
Vielen Dank erstmal für die Antworten und Vorschläge! Ich setze das mal so gut wie’s geht um dann wird man sehen was bei rauskommt! Hygrometer und luftentfeuchter Kissen sind am Start! Ich halte euch auf dem laufenden!
Viele Grüße
Drücke dir die Daumen, dass du die Feuchtigkeit schnell raus bekommst.
Ich weiß nicht ob das auch noch was bringt, früher sagte man immer, man soll alte Zeitungen unter die Fußmatten legen. Vielleicht hilft das auch noch ein wenig.
Hast du nachts eine Plane auf der Frontscheibe? Wenn ja, legst du diese danach in den Kofferraum?
Reactions: ekm
Plane hab ich keine. Hygrometer gestern besorgt, aber kein highend gerät. Ob die 79% Luftfeuchtigkeit tatsächlich stimmen weiß ich daher nicht sicher aber mein Anliegen habe jetzt an die Verkaufsleitung weitergeleitet. Mal gucken was dabei rauskommt! Luftentfeuchterkissen habe ich jetzt auch gekauft. Ich gebe mal nen Zwischenbericht ab, sobald ich näheres erfahre. 👍🏼
Sind die 79% im warmen oder kalten Zustand im Auto?
Die 79% sind am Morgen. Kalter Zustand. Zumindest ist die Windschutzscheibe nicht mehr so arg gefroren dank der luftentfeuchter Kissen. Ein Pluspunkt!
Ok, im warmen Zustand wäre das "nicht gut" gewesen.
Unter 67% geht das aber auch im warmen nicht. Also das Problem bleibt so oder so… ich hoffe auf eine zügige Rückmeldung des händlers. Leider haben sie erst dann reagiert als ich über CUPRA eine eher mäßige Bewertung abgegeben habe… aber ohne offiziellen Druck geht da leider wie so oft nix
Bei dem Wetter würde dass auch nur durch 2-3 Stunden Fahrt am Stück etwas ändern, immerhin muss sich alles erstmal aufheizen um Temperatur aufzunehmen und Feuchtigkeit abzugeben. Wenn du den Inneraum extern beheizen könntest und dann so wie @JoergFB58 schon schrieb mit dem Wechsel zwischen Heizen und Lüften arbeitest, sollte sich dass auch deutlich verbessern.
Ich habe mit dem Auto tatsächlich schon zweimal 400 km Wegstrecke am Stück hinter mir mit entsprechend Heizung, Klima etc.Geändert hat’s an der Feuchtigkeit leider nichts
Do you have unwanted water ingress in the car? Are all seals okay? Do you have water in the spare wheel well? This can happen with some ROC's; then the drainage hoses from the fuel filler neck are leaking, clogged, or not properly connected.
p.s. (after #17): are the gap dimensions of the doors correct, have you already checked under the floor mats?
defekte Dichtungen sind auch meine Vermutung. Aber ich warte noch auf die Rückmeldung des autohändlers. Sie wollten sich zeitnah melden. Aber das ist ja ein dehnbarer Begriff… 😉
79% Luftfeuchtigkeit sind weder im warmen und erst recht nicht im kalten Zustand gut. Das es an den kältesten Gegenständen, hier eben die Scheiben kondensiert und dan bei diesen Temperaturen friert ist normal. Reinste Physik. Sei froh dass es an den Scheiben ist und nicht wie in vielen Häusern in den Wandecken etc. und dann schimmelt. Früher hatte man solche "Eisblumen" auch an der Einscheibenverglasung in den Häusern, heute hat man vielfach den Schimmel.
Die Feuchtigkeit muss raus, woher sie auch kommt. Entweder durch nasse Klamotten, Schuhe, Schnee oder auch Undichtigkeiten. Lüften, lüften , Heizen & Luft austauschen.
Wobei defekte Dichtungen heutzutage eher selten sind. Ein erster Test wäre die Fahrt durch eine Waschanlage (mit Unterbodenwäsche). Gerade bei so einem neuen Fahrzeug, was ja max. 6-7 Mon. alt ist, kann ja kaum ein Ablauf verstopft sein. Wobei du schreibst ja, er wäre sogar erst nur 1 Woche alt. Auch auf dem Transportweg wird der sich kaum etwas eingefangen haben.
Wo wohnt dein Garage, liegt/lag dort Schnee? Viel Regen oder wie anderen Regionen eher kalt & trocken?
@JoergFB58 Du hast es so gut formuliert, dass ich kaum widersprechen kann :ROFLMAO: (möchte ich auch gar nicht).
Vlt. darf ich aber ergänzen, solange die Quelle nicht ausfindig gemacht ist, sollte man keine mögl. Variante schnell verwerfen.
Bei defekten Dichtungen hatte ich auch an das Pano gedacht. Kommt beim ROC schon mal vor, dass falsche Dichtungen eingebaut wurden oder bei unregelm. Spaltmaßen der Schließwinkel nicht ist, wie er sein soll und somit die Dichtung nicht richtig andrückt (dann klackert meist aber auch das Schloß im Schloßträger, den man nachjustieren kann). Beim Pano sind in wenigen Fällen ab und an auch die Abläufe zu bzw. ebenfalls die Ablaufschläuche verstopft. Gut, bei einem jungen KFZ sehr unwahrscheinlich. Wie gesagt, manchmal sind einfach nur die Ablaufschläuche nicht richtig verbunden. Da fällt mir ein, in einem Fall ging es um die Zwangsentlüftung. Ob das mit Wasserzutritt zusammenhing, müßte ich recherchiern, bevor ich etwas Falsches behaupte.
Erstmal nochmals vielen Dank für die vielen Antworten! Ich habe den Neuwagen gerade mal 2 Wochen. Also schon sehr ärgerlich aber zumindest der Händler reagiert jetzt. Montag geb ich den Wagen ab und dann wird geprüft woher die hohe Luftfeuchtigkeit kommt. Die können es sich selber nicht erklären. Leihwagen stellen sie zur Verfügung.
Ist ein CUPRA Leon VZ. Was er nicht hat ist ein Panorama Dach, eben wegen des angeblich leicht höheren Riskos von Feuchtigkeit im Innenraum! 😂
Ich bin gespannt ob die was finden. Falls das nicht der Fall sein sollte weiß zufällig jmd von euch ob das dann schon als gravierender Mangel gilt? Für den hoffentlich unwahrscheinlichen Fall der Fälle.
Das Auto macht ja sonst schon viel Spaß und fährt sich auch super! Auf lange Sicht sollte die Elektronik in dem relativ kurzen Zeitraum ja keinen Schaden genommen haben denke ich…
