Windshield wipers rattle
boomer
Hello!
I received my Cupra Leon ST VZ and have driven less than 900 km, and the windscreen wipers are rattling and making noises.
Is this the current state of affairs, and do others have this issue too? Or can this be claimed as a warranty case?
Is this also the current state of affairs and do the others have this too? Or can this be claimed as a warranty case?
hello boomer,
this is original equipment quality and also a well-known problem with the ROC. Unfortunately, there is nothing to claim. Even if the blades were replaced under warranty, the same rubbish would come back. Buy yourself "fresh wipers" from BOSCH and calm is.
I already thought so....
I never had that before with any leasing vehicles (all VWG).
There were some recommended here in the Forum. I should look up which ones those were.
Addendum: I see you already posted a link. Okay, thanks. I ordered it. Let's see if the problem stays away.
Das kann auch vom Harz der Bäume kommen.
Einfach mal lange spritzen und wischen. Oder mit nem Lappen und Reiniger über den Wischergummi fahren
Yes, I had thought and done that as well. But all the other previous vehicles did not have that problem, all from the VWG group and have been parked in the same spot for years. I will clean the windshield and wipers tomorrow and test it. The Bosch wipers should arrive on Tuesday, and I will compare them.
It was the same for me, then I bought new ones from the dealership, ERROR the same crap again after 2 months, the next ones will be sourced elsewhere.
It was similar for me.
Interestingly, the original equipment is also from Bosch, the Bosch logo is embossed, only the lettering is missing.
Probably, one can significantly degrade a fundamentally identical wiper blade if one wants to save "3 cents" (OEM).
I've also noticed that the originals are Bosch as well. I simply changed mine preventively after the winter, as I got the set of free wipers from the maintenance package at the end of the first 12 months. The old ones didn't rattle, but they had started to form streaks.
You also don't know how long the OEM wipers were stored before installation. Or/and there is an original equipment mixture (a cost-saving variant for the manufacturers), and with the officially sold ones, where the name Bosch becomes clear, a better mixture comes into play.
I have the originals from the Cupra dealer on the front and back, and they don't rattle. It might also be coincidence or luck.
I had the same problem indeed in 2022 when my T-Roc was new.
As a result, my windshield was treated with some kind of solution and it was gone for a short time.
When it occurred again later, VW covered 50% of the costs for new wiper blades, as it had only rattled on the driver's side.
Simply ridiculous! ;)
At the dealer, they have Bosch. In any case, I got those for mine.
@ekm
I didn't pay attention at all. While I was paying for the things, the service guy installed them.
@boomer The original windscreen wipers from the Leon are of poor quality. I assume they are from Bosch. In my previous Leon (Seat), the wipers made noise and juddered. Now with the Cupra Leon, the same problem again. In my earlier vehicle, I switched to Valeo and they were always excellent. I will also replace them in my Cupra with Valeo.
Yes, the originals weren't great....
Now I have the ones from Bosch for 18 euros. Visually, they look identical to those from Cupra, just as someone mentioned above, without the logo. But they wipe without rattling or making other loud noises. Therefore, a good investment, they don't cost much, bring peace, and I don't need to make an appointment at the workshop to try to prove that it's a warranty case just to get the same ones.
Interestingly, Valeo is also the manufacturer of the windshield wiper motor.
I personally always buy the wipers from Bosch - they were significantly better than the factory-installed ones on the Ford...
Rattling occurs with my Formentor as well. Treating it with RainEX solves the problem for a while. You have to reapply it more often at the beginning, but then it lasts longer.
Wow, I still have the factory ones on, no problems so far.... and mine will be 2 years old soon too... 🙈
I have the same problem with the front windshield wipers, with rattling and uneven movement.
Do they fit?
@Melfinos Yes, they should fit, as they haven't changed with the facelift. :)
