Modo eléctrico no disponible
waterpolo
Forenfan ★★★
Netherlands
Esta semana tuve con mi PHEV Leone ST 2 veces que se queda conduciendo con gasóleo. No se permitía volver a cambiar. Tuve que detenerme y encender y apagar el motor para conducir en eléctrico. Normalmente en modo híbrido utiliza ambos, especialmente cuando levanto el pie.
Adjunto la advertencia en el sistema de información y en el cockpit el símbolo E está tachado. A continuación, un enlace a un video con el mensaje en el cockpit:
¿Alguien sabe por qué se permite cambiar al modo eléctrico?
PD En el cockpit el símbolo E está tachado.
    1,4 MB · Visitas: 20
    1,7 MB · Visitas: 20
This behaviour can have multiple triggers. Some reasons to keep the combustion engine running apart from the two shown to you can be:
- self-diagnosis of the engine
- built up condensate in the oil
- regeneration of the OPF-system
Those are nothing to worry about, if it's not permanent.
If this problem is reoccuring, I suggest contacting your CUPRA-Partner.
I have his phenomenom at the end of last year when my e-Hybrid was new. Can't go back in the electrical mode. The (Highvolture)Battery at 80%, speed under 40Km/h or standing, so not to fast or battery down o_O
The problem was, that I have driven a too long time only in The E-mode, so the Low-12V-battery had less capacity. Drive more often in Hybrid-mode with the gasoline engine and the problem is solved.E-Modus.jpg
Today the car was normally working. A few weeks ago I was on vacation where I drove a lot on gasoline. Thanks for the info.
