Noticias de Actualización
Oh ok, one of the very early ones, had one myself.
Had the car towed 2 days before a planned appointment for update in April this year. It took nearly a week. They told me the update was big and the download gets interrupted...
Hope they fix your car fast without troubles afterwards! ✌️
Maybe you can annoy them to give you some true information what changes are applied and which components are affected :)
My car is back on the road. I get software version 2565, pervious 2480. The device code is now including the A, what early mentioned.
@ST4N , the comfort entry is available in interior menu, and it's working :love: .
@waterpolo congrats! Glad your car is working and now even better!
@ST4N , hopefully the flickering ledstrip isn't apply, what is mentioned on this Forum.
So now you are the one, doing races straight next to julianadorp every evening? 😂 Glad you are satisfied.
Don't know my exact Firmware, but the comfort entry is missing for me.
That's the same changes I got in April. I can say, for the early Facelift drivers, the update really made things better and fixed some annoying issues (false positive error messages). Not entirely bug-free (i.e. rear lights error) but better than the version the car came with.
Drive save ;)
I found on another forum that for the Formentor there is a device code with 'C' at the end, see link beelow
There was mentioned that last week a software update was available which brings the software version to 2768.
So, hab bei mir ein neues Update für die App..
    294,5 KB · Visitas: 48
I am waiting for a new Android version. Unfortunately the current 2.7.1 is starting slow or hanging on regular base.
Hab noch 2.7.1 , aber aktuell wird auch keine neue Version angeboten bei mir.
@waterpolo delete the Cache of the CUPRA App inside the "Apps"-Section of your Android Device and these problems are gone...
Después de la actualización del sistema a la 2565, todavía no tengo el menú Travel Assist con la opción para activar el cambio automático de carril.
¿Hay más vehículos FL con el sistema 'A' en los que esta opción no está disponible?
Tengo los sensores laterales de carril disponibles.
Ich habe dann auch einmal ein Bild meiner Systeminformationen gemacht...
Bei mir sind komplett andere Hardware-/Softwareversionen hinterlegt als noch bei @waterpolo am Dienstag :unsure:
Man sieht auch wie gut die Matte Displayfolie ist... 😬✌️
Mis informaciones de HW: 1000118936.jpg
Bastante software diferente por aquí, según el sistema no hay ninguna actualización disponible.
@waterpolo : Sí, lo tiene. Tiene exactamente la misma versión que tú. Está oculto en el menú de Asistencia de Viaje.
After the system update to 2565 I haven't still not the Travel Assist menu with option to enable automatic lane change.
My car was the same like you describe.
Are you 100% sure you have the additional sensors on your car? Not only the ones for park distance control but one additional sensor per wheelhouse? Maybe you can show a photo from the side of your car to verify.
My car, early Facelift, was missing these sensors.
@MarcelSTVZ , no tengo el menú de Travel Assist. ¿Puede que tenga un paquete de Intelligent Drive diferente? Hoy he enviado un correo electrónico a CUPRA para obtener más información.
@coopra , no tengo sensores en el paso de rueda, ¿puede que eso falte?
@MarcelSTVZ , thanks for the photo's. I don't have the marked sensors. This is the explanation why I haven't Travel Assist option.
Right.
