Schlüsselbatterie wie oft wechseln/tauschen?
das kommt bei Google raus:
  • Synchronisierung durch Zündung: Stecken Sie den Notschlüssel (aus dem Funkschlüssel entnommen) in das Schloss der Fahrertür und schließen Sie das Fahrzeug auf. Starten Sie den Motor innerhalb von 30 Sekunden.
  • Reset durch Tasten: Nach dem Wechseln der Batterie (Tipp: Vor Einsetzen der neuen Batterie die Öffnen- und Schließen-Taste für ca. 5 Sekunden gedrückt halten, um Restspannung zu entladen).
@Ice-Mark , I already tried the synchronization procedure which is little different than Google described. One importing thing is missing. The carkey has to be put in the middelconsole near the 'keyless' detection point. Otherwise the car can't be started. In my case I can start the engine, but in the dashboard it shows that the carkey can't be detected.
Btw, the car alarm goes on. It feels like you're breaking into your own car.
I will try this evening the reset procedure. For me it wasn't clear which button(s). In the Manual* I didn't read anything about this.
Update: the reset combination doesn't working unfortunately.
I have already followed the Manual* procedure.
I had contacted the dealer. May be the car key has to be recoded. The key wasn't during service begin December where I also received the PV4 software update.
Begin March I have an appointment by the dealer. I will let you known what the outcome is.
--- Problem solved :love: ---
It turned out to be the battery after all. Today I happened to come across a box of CR2032 button cells in a completely sealed package. I gave it a try. When I inserted the button cell, I immediately saw the red LED light up. Then I tested it by opening and closing the car, which worked without any problems.
I still find it strange that the spare car key needed a more powerful battery.
interessante Beiträge.
Kann mir jemand sagen, ob beim Terramar angezeigt wird, dass die Batterie schwach ist? Ich habe bis jetzt einen Seat Ateca gefahren, da wurde es nicht angezeigt. Ich stand schon vor dem Auto und nichts ging mehr. Sehr ärgerlich, wenn es z.B. regnet und man dann an der Kappe fummeln darf, um mit dem Notschlüssel die Tür zu öffnen. Ich habe seit dem immer eine Ersatzbatterie im Handschuhfach, was aber für die Türe nix nutzt.
Gruß an alle.
Also ich kann zwar nur für den Leon sprechen, der zeigt es jedoch an.
Also ja, das Auto meldet sich rechtzeitig vorher.
Ab und zu gibt es auch bei frischer Batterie Probleme mit dem Kessy, aber nichts tragisches.
denke, bei allen Cupra´s wird "Schlüsselbatterie wechseln" im display angezeigt. Wüßte nicht, dass hier jemand schon einmal von Gegenteil berichtet hat.
Die Anzeige erscheint für ein paar Tage bei jedem Start, dann wird´s aber Zeit, eine neue einzusetzen.
Nicht vergessen: alte Batterie raus - Taste am Funkschlüssel drücken (reset) - neue Batterie rein.
bei mir ist es nun nach ca. 1 1/4 Jahr soweit. Im Display die Anzeige Batterie beim Schlüssel tauschen.
Mein Schlüssel ist nach 1 Jahr und 9 Monaten immer noch mit der ersten Batterie im Einsatz. Der Zweitschlüssel, der seihher in einer abgeschirmten Hülle verpackt war und letzte Woche mal kurz genutzt, wurde zeigte mir gleich an dass die Baterie gewechselt werden muss. Ist auch nicht ganz nachvollziehbar. Batterien sind die guten Panasonic.
Ich meinte die Panasonic war ab Werk drin, die halten erfahrungsgemäß am längsten.
Edit: Den Amazon Link habe ich erst jetzt gesehen. Da muss man immer vorsichtig sein, auch wenn es die richigen Batterien sind, wenn man besonders günstige Angebote wählt, bekommt man evtl. jahrelang gelagerte Batterien, die am Ende nicht länger halten als die billigen Ikea Batterien.
Das Problem hatte ich vor kurzem. Ich musste meine Batterie tauschen und habe noch zufälligerweise welche da, gehabt die ich Anfang des Jahres für etwas anderes bei Amazon bestellt hatte. Habe sie eingelegt und es ging nichts ( Rotes Blinklicht hat geblinkt). Erst dachte ich das der Schlüssel angelernt werden muss. Ging nicht
Habe dann die alte nochmal rein und damit funktionierte es. Batterien kaufe ich nur noch in einem Markt. Bekommt mann ja auch bei Rewe, Globus, Baumarkt oder des gleichen.
Erster Batterietausch nach ca. 3/4 Jahr.
PS: Was oder wie billig bestellt ihr da 🫣 ? Die Batterien haben ein Art MHD aufgedruckt, bis zu dem die Verwendbar sein sollten. Da hab ich bei meinen Bestellungen über Amazon locker je noch 8-10 Jahre. (i.d.R. Varta)
Ja, aber eine 10 Jahre alte Batterie hält halt nicht mehr so lange wie eine eine 2-3 Jahre alte. Es guckt halt kaum jemand das Datum, die meisten kaufen nach Preis und bei den gaaanz billigen sind es dann eher nur noch wenige Jahre bis MHD Ablauf. Und dann ist eine Varta auf dem Niveau von Ikea.
Wenn du Batterien mit MHD 2034-36 hast passt das doch. 😉👍
Achtung Ironie: durch Zeitverlauf wird die Varta also besser?
Ohne Flax: Varta Zellen sind schon lange der letzte Mist, egal ob Consumerbatterien oder als Starter. Kein Wunder, dass die pleite sind.
Mein Schlüssel fängt nun nach 1,5 Jahren an sich komisch zu verhalten. Kessy sowohl im Auto (Zündung) als auch außerhalb (Ver-/Entriegeln) funktioniert einwandfrei. Die Schlüsselknöpfe aber nur noch sehr unzuverlässig (Manchmal gehts (auch von weiter weg), manchmal nicht).
Musste gerade über das Schloss (inkl. Alarm ...) öffnen da ich Keyless ausgeschalten hatte.
Die LED am Schlüssel blinkt auch nicht mehr. Weder wenn ich auf einen Knopf drücke, noch wenn sich der Schlüssel in der nähe des Fahrzeugs befindet.
Allerdings zeigt mein Cupra auch keinerlei Warnung an, dass ich die Batterie wechseln soll. Irgendwie alles inkonsistent.
Oh. Das kenn ich inzwischen auch. Alles, wo man die Tasten lange drücken muss , wie Komfotöffnung der Fenster, Kofferraumklappe, geht nur noch alle heilige Zeit. Einfaches Entriegeln klappt aber. Kessy hat sich gefühlt auch verschlechtert.
Letzter Batterietausch vor etwa 3 Wochen, hat nichts gebracht.
Bin nächste Woche sowieso in der Werkstatt da werd ichs mal platzieren...
