Leoncito
Hello, I have been driving a Cupra Leon 1.5e TSI for about a year now. I have noticed that with the SSA deactivated, the engine still keeps turning off constantly. I have already done some research here but found nothing about it. Does anyone know more about this? I must also honestly admit that driving like this is quite annoying.
Since you mention the start-stop automatic (SSA), do you mean when the car is stationary and not moving or rolling?
If SSA is deactivated, the 1.5 TSI should not switch off. I'm not entirely sure, but with the 1.5 eTSI there might possibly be a "Einstellungssache" (reserve battery capacity) be.
Thank you for your reply, the engine cuts out as soon as I take my foot off the accelerator, for example when rolling at a traffic light. When I come to a complete stop, the engine starts again.
That sounds like the coasting mode. Try to see if it also occurs in the "Sport" drive mode. If it doesn't, then it is the coasting mode, which is standard in Eco and also in Comfort mode for the 1.5 models.
I can confirm, I’ve also been driving the eTSI for 3,000 km:
In Sport mode, the engine basically goes into neutral but doesn’t switch off. ACT (2 cylinders) also kicks in during Sport if very little load/power is required.
In Comfort or Eco, the engine really switches off very quickly while driving, both on straight stretches when coasting, but sometimes just braking and coasting into a corner is enough.
I also find it a bit strange that it switches off right at the corner entry and then immediately back on again when you want to accelerate further.
Is this really economical?
Do you have more or less wear and tear from the on & off?
I drive a lot in the city in ECO and just hope it’s not “damaging”…
By the way, disabling Start/Stop doesn’t affect this at all: if you “coast” towards a red light and brake gently to a stop, the engine stays off. But if the car is stationary and you had SSA disabled, the engine then restarts while still stopped – completely bonkers :ROFLMAO:
I see it exactly that way, it's a design flaw for me, luckily I only leased the car, but I still have to deal with it for another 2 years. I made a mistake and ordered the car almost blindly, my fault.
@Leoncito wieso einen Fehler gemacht? Der Motor schaltet sich nicht wirklich spürbar aus,wenn er nicht benötigt wird und er reagiert zuverlässig schnell wenn die Kraft benötigt wird. Das ganze System dahinter hilft dir tatsächlich Sprit zu sparen und das merklich. Insofern ist doch die Technik genau die die du gekauft hast 🤔
@Philzstift84 Sehe ich ganz anders. Wenn ich die Möglichkeit habe die SSA zu deaktivieren und der Motor merklich trotzdem ständig aus geht ist das für mich ein Mangel und eine Fehlkonstruktion. Und Spritsparen tut diese Technik keineswegs, es nervt einfach nur. Ich habe das Fahrzeug mittlerweile reklamiert, da noch sehr viele andere Mängel vorlagen und die Leasing hat das Fahrzeug tatsächlich nach einem Werkstattbesuch und einem Gutachten zurückgenommen. Ich bin diese Karre zum Glück los.
Ja, das mit Start-Stopp ist nicht wirklich intelligent gelöst, schaltet man es aus, geht der Motor beim Rollen an die Ampel in den Segelmodus (also schaltet sich ab) und sobald man steht springt er wieder an. Deshalb lasse ich es einfach so, weil dann im Endeffekt sogar weniger An-Aus-Phasen sind.
Für die, die wollen das der Motor gar nicht ausgeht, gibt es die Möglichkeit das Start-Stop zu deaktivieren UND in den Performance Modus zu wechseln, dann sollte der Motor auch dauerhaft an bleiben.
Das ist halt der Vorteil des Mildhybrid, wer das nicht möchte muss halt zum normalen 1,5er TSI ohne Batterieunterstützung greifen. Gerade dafür wurde die Hybrid Technik dort doch integriert.
Das ist kein Mangel, sondern unzureichende Information vor der Bestellung und damit falsche Motorwahl.
@JoergFB58 gebe ich dir vollkommen Recht, meine Intention in der Deaktivierung von Start-Stop lag eher im Bereich von Kurzstrecke mit Ampel und kalten Temperaturen. Bei unter 0 Grad und unter einstelligen km-Strecken brauchen Motor und Batterie das nicht zwingend.
Sonst ist es aus den von dir genannten Gründen ein gewolltes System.
Weil es zum Thema passt, ich habe festgestellt, dass zwischen eTSI im Hatch und im ST noch Unterschiede sein müssen. Bin den 1.5er FL damals als Hatch Probe gefahren und da war noch die "2-Zylinder-Abschaltung" und mMn hatte der in den Profilen auch einen "Eco"-Modus. Beides hat der ST nicht.
Die modernen Mehrbereichsöle/Motoren beherrschen auch das, ebenso sind auch Starter & Batterie dafür ausgelegt. Zumindest wenn man nicht gleich den rechten Fuß voll durchdrückt und einigermaßen sinnig fährt. Wer allerdings meint nach 2/3 Jahren geht die Kiste sowieso wieder weg, da Leasing, dem kann bzw. ist doch eh egal. Der läd auch seinen PHEV/BEV immer auf 100%, anstatt die Batterie schonend langsam nur auf 80% zu laden.
Bei meinem PHEV kann ich S/S gar nicht abschalten. Auch im Hybrid-Modus fährt er elektrisch, wenn ich mich mit dem rechten Fuß beherrsche und mich auf der Landstr./Stadt eher im unteren Gecshindigkeitsbereich befinde. Gut der Akku muss dazu halbwegs geladen sein, sonst klar kommt auch da der Verbrenner. Kurzstrecken werden aber so rein elektrisch erledigt. Durch die viel höhere elektr. Reichweite gegenüber dem vFl. ist dies ja auch prima machbar.
Die 177 Benzin-PS bzw. 272 PS im Verbund mit dem E-Motor sind natürlich auch ein Wort.
Rein wirtschaftlich macht es sicher kaum einen Sinn, dann wäre der Diesel sicher noch die beste Wahl. Zumindest wenn man die Anschaffungskosten, Betriebskosten, etc. über die gesamte Haltungsdauer berücksichtigt. VZ333 & Co. sind dann sowieso jenseits von gut und böse. Aber Spaß kostet halt, so oder so.
Der rechte Fuß & Kopf entscheidet 😜😁
Sehe ich auch so. Außerdem hat er das SSA nicht wrklich verstanden.
hast recht, ich habe diese dämlich Technik nie verstanden, aber kein Problem, die Karre ist mittlerweile weg und ich bin das Problem los. Die Leasing hat das Fahrzeug anstandslos zurückgenommen, da noch mehr Mängel vorhanden waren.
Nur mal aus Interesse, was waren die anderen Probleme? Da hier ein paar User, mich eingeschlossen, lange gekämpft haben oder es sogar noch tun, fände ich es einfach interessant, den "schnell" scheint sowas eigentlich nie durch zu gehen.
Hab mir das Thema auch nochmal durchgelesen und mit ein paar Monaten mehr Erfahrung als bei meinem ersten Kommentar kann ich sagen: Das, was du beschreibst, ist der Segel Betrieb des eTSI, nicht mehr und nicht weniger. So und nicht anders fährt sich de Mildhybrid eben, außer wie schon geschrieben im Sport Modus.
Umso interessanter, was eben die anderen beanstanden waren, muss ja schon schwerwiegend gewesen sein..?
Hast du ein anderes Modell oder Motor bestellt, oder bist du ganz aus dem Cupra Lager weg?
gerne, hier die Auflistung der Mängel, es handelte sich wie beschrieben um einen 1.5eTSI
- Motor geht aus obwohl SSA deaktiviert
- Ruckeln beim Anfahren
- Knarzen im Innenraum (Türverkleidung Beifahrerseite, Ablage Fahrerseite, B-Säule.
- Fahrersitz knarzt beim Aussteigen.
- Notbremsassistent löste mehrmals plötzlich aus
- Störungsmeldung: Bitte Startersystem prüfen, wurde anscheinend bei der Inspektion behoben, trat aber danach trotzdem etliche Male auf
- DSG "vergisst" zu schalten (Comfort Modus)
- Spiegelabsenkung Beifahrerseite ging nicht obwohl aktiviert.
Habe das gleiche Phänomen beim Terramar... Gut bin jetzt etwas schlauer aber nicht zufrieden. Ich roll an die Kreuzung (SSA deaktiviert) Motor geht aus, die Steuerung bekommt dann wohl `´mitgeteilt`` denk dran SSA deaktiviert und der Motor startet wieder und geht auf knapp 1000 U/min. Wenn so der Plan ist, kann man auch die SSA aktiviert lassen. Hmmmm fällt mit schwer, an Sprit sparen, keine zusätzliche mech. Beanspruchung oder Nachhaltigkeit etc. zu glauben.
Das liegt daran, das er im "D" Modus trotz deaktiviertem SSA segeln möchte (um Kraftstoff zu sparen) deshalb ist in "D" die Deaktivierung von SSA sinnfrei. Soll der Motor permanent laufen SSA deaktivieren und in den "S" Modus schalten. Segeln und SSA sind nunmal der Hauptgrund mit dem eTSI spritparend unterwegs zu sein.
Hi everyone,
I’m new here and registered specifically because of this problem. I also find this coasting extremely annoying. I do understand the purpose behind it, but I really don’t understand why it still wants to coast below 10 km/h when approaching a traffic light.
This could definitely be optimised. It’s just catastrophically programmed if they only saved shutdown times of 1–2 seconds.
This is once again a shortcoming that might have been solved more simply in the pre-facelift but just works perfectly. I don’t understand why the engineers always have to make things worse while trying to improve them. The result is that what worked perfectly in the pre-facelift no longer works in the facelift. Simply disgraceful... I’m so glad that my 5-year-old Leon PlugInHybrid works perfectly. And woe betide anyone who tries to install an update on it without my permission during a possible workshop visit. I’ll chase them all the way to the factory premises...
