DIY Accessories
Okay, yes, that's true, I hadn't considered the resin like that. If it has to be painted anyway, it makes sense.
Sehr schönes Gadget. Wo bekommt die Anzeige die Daten her, OBD2 Stecker->Smartphone->Anzeige?
Okay, the display communicates directly with the OBD2 connector. The "ESP32" component is certainly built into the display and can be controlled externally to change the display? I'm not very technical, I just want to understand the communication path. I only know how to read data with an OBD connector + smartphone or diagnostic device.
The important question is ;) , where exactly can you find this info that runs through (ignition angle retraction). So under which control unit. That's the info I would like to have when I play around with the OBD11. I haven't found it there yet (probably also poorly or incorrectly translated into German).
I also spent a long time on the values, as they are not in the standard OBD; for me, the IDs are as follows:
13F2 / 13F3 / 13F4 / 13F5IGA_CYL_KNK [0..3]: Rücknahme Zylinder 1–4
138A / 138B / 138C / 138DIGA_IGC [0..3]: Zündwinkel Zylinder 1–4
For IGA_IGC, a conversion factor of raw value × 0.37475 − 35.625 ° is needed.
For IGA_CYL_KNK, I only know that 0x80 is 0°, with the same conversion factor yielding somewhat plausible values for me, but I still need to do a few test drives to see if the scaling works.
This is how I arrived at the values:
ATSP7 (CAN 29 Bit, 500 kBit)
ATCP17ATSHFC0076 (0x76 = Engine Control Unit, 0x77 probably Transmission)
ATCRA17FE0076
ATFCSH17FC0076
ATFCSD300000
ATFCSM1
ATAT1, ATST64 (I had to raise the timeout to 400 ms here, as the responses seem to go through several hops)
And then service 0x22 with the IDs as above.
I had to query each cylinder individually because my Bluetooth adapter can only request 2-3 IDs at the same time; otherwise, it becomes unreliable.
Could you send me the STL for that?
I have also been eyeing the originals... but that also looks like a truck..🫠
You're the best!
I also find the display mentioned above very appealing. I don't have any experience with OBD or what all can be read from it. But in connection with the hybrid, there might be some really nice features. I need to see if I can put something like that together.
The engine cover for the VZ4 will indeed turn out to be much "cleaner" than initially thought:
The costs for the external printing in one piece are around €800-900 🫨
For me, I have to print the part in 4 pieces, which means of course doweling/gluing, filling, and sanding. Let's see when I feel like doing that.
Edit: If anyone has suitable design ideas, feel free to share them.
The example already looks good. A carbon variant would alternatively be possible for 800 - 900 euros.
It's primarily about the fact that it's "self-built accessories" 😉
