Incorrect tire dimension leads to sensor failure and thus to a €6000 workshop bill.
Schorsch
Hello,
I installed the winter wheels from an old Leon on my leased CUPRA Leon ST VZ (333 PS) with first registration in 10/2025.
Unfortunately, I must have misread or made a mistake somewhere and therefore installed these wheels with 245/40 R19. The correct dimension would have been 235/35 R19.
This allegedly led to an intermittent error of the (radar) sensors over time and to the failure of, among other things, the pre-crash function. After more than 10 weeks without a car or replacement vehicle, because the vehicle had to remain in the workshop, the summer wheels have now been mounted.
With the original tires and all replaced sensors, the error no longer occurs!
I am already aware that I made a mistake regarding the tires, but now I am supposed to pay over €6,000 for the new sensors and the labor to be able to retrieve the car.
What do you think about the whole situation? Do you see any possibility, a loophole or anything else to avoid these costs, which are disproportionate to the leasing costs (only 24 months) etc.? Could any insurance possibly step in?
I am really shocked and overwhelmed right now!
Thank you in advance for your contributions!
Hallo @Schorsch and welcome to the Forum,
that the wrong tyre size leads to implausible signals in any control units is fundamentally understandable (speedometer deviation > 5%), so the radar can certainly react offended. However, I don't really understand how this circumstance alone could lead to an actual defect in any sensor, unless something in the wheel arch was mechanically damaged due to the too wide tyres or incorrect offset.
Did you receive a report or similar from the workshop that describes the derivation of the fault or which sensors were replaced?
Did you agree to the repair and the cost estimate, or were you informed in advance about the possible costs? The standard approach in such cases is lawyer + expert. Whether an insurance company will step in (if at all, your own comprehensive insurance) you need to read in the fine print or clarify whether consequential damages to the insured item due to self-inflicted negligence are covered.
- this is not legal advice and merely my opinion
Hello Milan,
thank you very much for the quick response! It already contains quite a bit of good and usable information for me.
Just for your information: I haven't received any report or similar regarding the derivation of the error. I will only get the original invoice and the vehicle after I have paid the invoice. Upon my inquiry, I was told that I should receive a preliminary invoice by email soon, which should at least clarify which sensors, etc., were replaced.
And oh yes, I did not agree to any cost estimate nor was I even asked whether sensors should be replaced, as all of this should apparently be based on warranty. But now I am supposed to cover the costs...
I will now call a lawyer from my legal protection insurance and ask there.
@Schorsch You can indeed use different tire dimensions on a rim - have you checked the certification for the rim?
What makes me suspicious right away is that the workshop needs 10 weeks to find a fairly obvious error. 🤔
In principle, there might also be the possibility to handle this through your private liability insurance (if available) - as long as this is not excluded in the insurance policy - since you caused damage to someone else's property.
Please look up the exact designation of the rims.
A little food for thought: how many people are there here in the forum who have had ongoing problems with the installed sensors (high beam assistant, etc.) for a very long time - which should be comparable to a faulty calibration due to incorrect tire dimensions...
The sensors don't just break over time; they are recalibrated once...
I could imagine that the sensors were not defective at all.
However, the workshop probably didn't notice that the errors were due to your stupidity - sorry for the expression - and therefore they just replaced everything possible - unnecessarily - and of course charged for it.
I think you will only get out of this with the VK, but I'm curious about how the story unfolds.
PS
You probably also drove without operating permission and thus, in the event of an accident, without insurance coverage. Be glad it turned out this way.
@all
Just because you have a car model xy doesn't mean you can mount wheels of the same model xy. That's why I always take the less problematic rims from the accessories.
PPS
Liability damage from the previous writer might also be a hot Tipp.
Hey guys,
thank you very much for your responses!
This is really a very cool forum here.
I can only agree with my own stupidity, I have no idea how something like this could happen to me (I'm not exactly inexperienced at over 40).
The operating permit would have, in case of emergency, also become a serious issue, and ignorance does not protect against punishment, as we all know. Fortunately, that turned out okay...
By the way, I also think that the sensors were not broken, but just kept throwing the same error.
I find the idea of liability insurance really brilliant, as this is really not my property!
In any case, the lawyer said that I should pay the bill just to get the vehicle back, but I must definitely write on the bill: “Expressly without legal obligation and under reservation of a refund.”
So that's the current state of affairs...
Thank you all and have a nice evening!
@Angefixt Unfortunately, I don't have the wheels here; they are currently on the vehicle. But the tire dimensions should definitely fit the original CUPRA wheels (as far as I know, they were also on the "old" Leon, but definitely approved for the Formentor VZ Hybrid), but unfortunately not anymore on the current Leon ST.
By the way: Does anyone happen to have the COC documents for the Cupra Leon ST VZ model year 2025 on hand and could share them here?
I would only have the one from the VZ Extreme
Does that help you?
Do you have the Akebono brake?
Maybe it helps.
You would only have been allowed to drive the Formentor OEM wheels with the correct tyre size if they were approved for individual use (if they can be removed without modifications, since the ET is smaller as far as I know) because they are only approved by the manufacturer for the Formentor. Therefore, it's better to sell these and buy a suitable set of aftermarket wheels with ABE for the next winter.
If I understand correctly, they want you to pay the costs upfront and the sensors are only to be changed afterwards, right? Is there a possibility to take the vehicle to another Cupra dealer before the repair (that is, after payment) to have the defective sensors confirmed? It would also be advantageous for the workshop where it currently is if the second diagnosis says the same. Due to the advance payment, it is ensured that you will have the repair (if it is really necessary) done at the current workshop.
As I understand it, the deal is already done. The workshop has been tinkering for weeks, swapping parts, etc., and wanted to fill their pockets through the warranty. However, the manufacturer then refused to cover the costs due to the wrong tires, and now they are looking for a "fool."
Was a workshop order signed when commissioning the warranty repair (which states that the costs may be borne by the owner)?
@ekm The sensors have already been replaced, but I dare to doubt whether the old sensors were really "broken" "only" because of a wrong input signal... unfortunately, that probably doesn't matter anymore.
I'm still wondering how such a high amount adds up. The sensors should total a smaller maximum amount of 4 digits. The rest is labor time + tax?
Parts are to be paid for in case of doubt, that's clear. The labor time should be significantly in your favor from the dealership. It's also a bit their fault...
I see it similarly; if a Leon comes with Formentor wheels, then a reasonably competent Cupra garage should notice the "mistake" at first glance.
@Schmitzibu We did not sign a workshop order and also did not verbally authorize the replacement of the sensors
I did some more research, and there are already relevant rulings from the OLG Sachsen-Anhalt regarding this.11.2.2010, AZ: 1 U 84/09Accordingly, the invoice must be paid even without direct commissioning of the workshop. However, this is only the case if it is - in their own words - justified and comprehensible.
> The work was immediately necessary to rectify the specific fault
> Replacement parts have been demonstrably installed
All of this can only be determined by an expert/assessor. If you manage to obtain a list of the specific parts that were replaced, we can at least make further assumptions. At the moment, it is not really comprehensible how the €6000 is supposed to come about.
The defective sensors are supposed to be included with it.
If they suddenly start saying, "they were disposed of," etc., you actually have the proof that something is going wrong.
Honestly, I'm baffled. In five years "next door," I've never read anything like this.
What do the radar sensors that measure horizontal distances to "obstacles" have to do with the wheel/tire dimensions? In the ROC, speed and consequently the driving distance are determined via driving time and the tire pressure from the number of wheel rotations. Does the Cupra use a different technique? Even if it does, sensors are there to detect and report anomalies in the matrix. Do they break because of that?
And if your VZ is already being held as collateral, are your lease payments also suspended?
I find the suggestions "liability insurance" and "handing over the supposedly defective sensors" good.
Good luck!
So, dear people... the thing with personal liability insurance and damage to the leased car can generally be written off. You could claim every scratch caused on the leased car since it is the property of someone else. Tell me... where do you live???
on Melmac. :ROFLMAO:
One could generally claim any scratch caused on the leased vehicle, as it is the property of another.
That's why my question to you Earthlings: what else is personal liability insurance for if it doesn't cover damages to "someone else's property"? This is a matter between the PHVV and the VN and not between Cupra and the lessee, right? :confused:
