Incorrect tire dimension leads to sensor failure and thus to a €6000 workshop bill.
@Cupra-Klaus it may be part of your nature to write provocatively; at least you stand out within individual threads and occasionally receive backlash from the authors. At this point, you refer to something I had brought up...
To quote you - in what world do you live that:
"possibly also opens the possibility to run the whole thing through your private liability insurance (if available) - unless this is excluded in the insurance policy"
is interpreted by you as a definitive statement that this should be handled through this form of insurance?!
At this point, I advocate for sticking to the facts. It was simply meant as a hint that @Schorsch this once checked by your lawyer or in parallel inquiring with the insurance company.
We are all not full lawyers in leasing law, and private liability insurance does indeed cover damages to "rented vehicles" to a certain extent. Leasing contracts are ultimately a kind of "rental model" - surprise. Therefore, the logical conclusion to at least have this checked - in my layman's assessment - is not so wrong.
Even if you should be right that such damage should not be covered, it has @Schorsch here's another opportunity to have it checked, so as not to be stuck with the damage. The comprehensive insurance (which is mandatory for a leased vehicle) was already presented as an option beforehand - but the damage did not occur due to an accident, but rather in the course of normal, everyday use due to a prior oversight.
To return to your question about the world we live in - at least I live in a world where we help each other, respect one another, and should also behave/write like that on the internet - that's exactly what such a Forum is meant for in my world. It serves as a concrete support system, should someone be able to offer a solution, as well as a mere exchange of thoughts - even if the given prompts may not always turn out to be correct.
Thus, the affected individuals often benefit from the constructive discussion.
By the way, surprisingly, insurance agents also belong to the previously described type of people on our planet, who know how to exploit such "loopholes" if you happen to be a long-term customer with numerous policies with them...
Otherwise, it really is: "Houston, we have a problem!"
Over and out...
Damage to someone else's property is generally covered by liability insurance, but only if the non-owner using the damaged item was not entitled to use it based on an agreement, as is stipulated in the present case by the leasing contract.
Although Cupra remains the owner of the item, the leasing contract holder = driver is the agreed lawful user and steps into their place.
Therefore, in such cases, liability insurance is excluded. ;)
@Willewatz That's a very good point that can be worked with. Thank you for that.
So, would the full comprehensive insurance be the maximum option here, or do corresponding exceptions apply here as well?
As far as I know, comprehensive insurance will not apply either. It usually only covers accident damage, or damage caused by vandalism, theft, natural forces, glass breakage, or short circuits in the wiring. But please do not consider this list as exhaustive. Perhaps there is still a gap for other damages that a savvy insurance agent can identify in the interest of their client. ;)
I can't imagine comprehensive insurance. In the unlikely event that there is a point under which it could be classified, there are again several points for a rejection - a modification, with missing individual approval, which could even lead to the loss of the operating permit (?), which would already be a reason, or it could be classified as "grossly negligent," which would also mean a loss of insurance coverage.
I would rather try, as described above, with an expert assessment regarding the causality between the larger wheels and the (alleged) failure of the sensors. The difference between an empty and a fully loaded vehicle should not change the position of the sensors (even if downwards, not upwards) much less. And that should not lead to damage to the sensors either.
@Willewatz For that very reason, comprehensive insurance was also out for me personally, and liability insurance was a possible option - but as mentioned, someone who has more background knowledge needs to check that, and as you already said: perhaps the insurance representative finds a gap in favor of the customer.
@Schorsch It would definitely be good if you could share the insights from this so that in the future, other people know what they could do if similar damage occurs to their leased vehicle.
The car insurance provided by Cupra includes coverage for own damages up to 100,000 or 200,000 in comprehensive and liability (e.g., garage) outside of the basic coverage. However, I cannot determine whether negligent installation of unsuitable tires is covered.
The note is more intended due to the blanket statement that one's own insurance would not cover own damages.
Thank you very much for the detailed explanations. I don't think legal expertise is needed to recognize that there is simply no insurance that covers the costs for damages caused by a lessee to the leased item. Otherwise, the leasing business would generally be rendered absurd.
So you would need to explain the causal relationship to us - because the lessor is not necessarily the insurer...
Who the lessor receives the money from in the event of damage should be of little concern to them.
According to your argument, any "rental business" would be rendered absurd (since damages caused by the renter could be covered by private liability insurance - depending on the insurance coverage ).)...
@Schorsch I once inquired for you and received the answer that the revocation of the operating permit (due to the unauthorized rims) will have an absolutely negative impact, so that no insurance will apply.
@Angefixt
The causal relationship of the absurdly conducted leasing transaction would simply consist of the fact that then every lessee could handle the leased item as they please, since the private liability insurance would cover the damages caused. I still doubt the seriousness of anyone believing they could claim their private liability insurance for such caused damages.
@Cupra-Klaus If you would read other people's posts more attentively, you would have noticed that there was indeed talk of comprehensive insurance here, and the liability insurance was only referred to later in the discussion as an example for the regulation of self-inflicted damages to rented objects.
It would certainly be possible to settle a damage, as it (according to the workshop's statement) occurred, through the comprehensive insurance - but as correctly suspected, the expiration of the operating permit due to the wrong wheels/rims will @Schorsch to become a problem.
Since the discussion with you regarding the actual topic of the thread does not provide any added value, this will remain the last well-intentioned hint in your direction. ✌️
@Schorsch I once inquired for you and received the answer that the expiration of the operating permit (due to the unauthorized rims) will have an absolutely negative impact, so that no insurance will apply.
That's exactly how I see it too.
