Leon ST VZ 333 ABT Tuning to 400 hp
@Cupra-Klaus
With "the" I obviously meant ABT – after all, that's the title of the topic and the entire excursion revolves around the ABT box. Furthermore, it is even explicitly shown in the characteristic curve image as ABT Box G4 marked. :D
But I'll just blame it on the temperatures – at 35+ °C, it seems that not only the charge air cooler starts to suffer.🌡️:P
@dantheman
Thank you for the clarification. Now I have seen it on the characteristic curve image as well. There are things... :rolleyes:
The colleague in question apparently did not want to believe that the ABT box is not worth its money and therefore went to another dynamometer.
Since pictures, as we know, say more than words...
That's at most the standard performance, but nothing more!
@dantheman So, in terms of the progression, I would even formulate it more drastically: here, only the torque has been changed to feign "increased performance."
Because that's exactly what our "butt dyno" notices in this case - a higher torque that is available earlier (at a lower RPM).
I don't know if we can already speak of a deliberate deception here - but a company that is at home in motorsport cannot ignore such results.
How is the box specifically advertised?
So the application is already very contradictory. The 360/370 hp is achievable - as mentioned in the body text. However, it seems that the text block for the 310 hp CUPRA was used here...
And the box was measured with a Golf R Manual* transmission at an ambient temperature of 15.2°C three years ago.
Right. I still have the old block. Formentor 2.5-liter Audi engine with original 390, thanks to ABT 450 hp. With that, I can take down any Audi RS3/QRS3. 0 to 100 in just under 3.5 seconds.
Regards
The colleague in question apparently did not want to believe that the ABT box is not worth its money and therefore went to another test bench again.
That is at most the standard performance, but nothing more!
Is 29.8° temperature good for a measurement? What else does the car have installed? Open intake, for example? I'm asking as a layman.
@Cinobert
One must not forget that it is not only the temperature that is crucial. It also depends on how many pulls have already been made and how good the cooling of the test bench is overall. After several runs, the intake and charge air temperatures rise, causing the control unit to reduce power can. A test bench with powerful cooling air often delivers better and, above all, more reproducible results than one with weaker cooling. Therefore, the pure temperature is just one factor among several.
As for the vehicle itself, unfortunately, I do not know what all is installed. As far as I understand, it is stock except for the ABT box.
Provided good cooling, the air temperature is actually irrelevant, as this is corrected according to the parameters of the EWG standard.
Primarily, the oxygen content in the air is crucial, and secondarily, the temperature. However, it fits: The colder the air, the higher the oxygen content!
@Gelöschtes Mitglied 3250
With 15 years of experience in engine construction, you should actually be able to distinguish between oxygen content and oxygen mass.
The oxygen content of the air is around 20.95 vol-% and does not change significantly with temperature. Cold air does not have a higher oxygen content.
That is exactly why every manufacturer installs an intercooler in turbo engines: Not because the oxygen content increases, but because the air is cooled after compression, its density increases, and thus more air mass and therefore more oxygen mass enters the cylinder at the same boost pressure.
The correct statement is therefore: The colder the air, the higher the air density – not the oxygen content
I completely agree with you and give you 100% right. That's what I meant with my statement, sorry if I expressed myself unclearly and incorrectly.
My wife and I were guests at ABT in Kempten with our ABT Cupra VZ in the last few days and we really felt well cared for and at home... and that in the best weather in beautiful Allgäu:
