Maps via Android Auto night/day mode faulty
racinggoat
Google Maps almost always shows a dark map via Android Auto. Even when it is bright outside. Only very rarely, maybe 3 times so far, has the map display been bright.
Where should I look?
Infotainment in the car,
settings on the phone,
any brightness sensors on the car?
Any tips?
Response from another thread:
It is supposed to be fixed via an update.
I actually received a reply from Cupra today regarding the problem:
"We have received feedback from our technical department that they are aware of this issue, but unfortunately, there is no short-term solution.
The problem should be resolved with the next updates of the infotainment system."
At least Cupra knows about the problem and they are trying to fix it with the upcoming updates. Let’s see what awaits us.
Update of the "infotainment system"? So you mean the ABT = Audio Control Unit? :D
I wouldn’t have even noticed – I always drive with dark mode wherever possible.
Today, of course, the opposite. Bright from the start.
PS: Yesterday, the display switching (consumption values) in the "speedometer display" opened up during the drive 😬
The problem is known at Cupra. Current workaround: After starting the vehicle, manually switch the dipped headlights on once and then back to automatic; this will enable the switch from Dark to Light Mode.
Alternatively, briefly drive under a bridge, where the lights will turn on and then off again, which also makes it work. Or start in an underground car park; then it will also work when exiting into daylight.
