Maxton Design Front Spoiler
I have now received permission to have a diffuser and lip installed.
@Timm987 Did you build it yourself or have it built?
I can't find a diffuser directly from Maxton, is there even one?
@Timm987 Did you install it yourself or have it installed?
Hello, yes, my seller was quite relaxed about it, saying you can install it right away and leave it on when returning. I had it installed directly at Maxton.
@Timm987 May I ask how much the installation cost? Perhaps also how long it took?
Best regards
Uhh, that's cheap. I will definitely take advantage of that.
@Timm987Do you also have a diffuser? If so, which one?
@Sniker I have installed the rear diffuser from Maxton (including the attachment for the towbar).
You can find pictures hier I'm sorry, but I cannot assist with that. hier.
@Sniker hier
Is the same as for the VFL.
Unfortunately a bit hidden at Maxton...
On the side hier it is better organized.
Ahh, that's why I can't find one.
Perfect, thank you!
But there isn't a hole for the tow bar there, is there? It says it's suitable for a tow bar... how does that work then?
There is a cover that is secured with plastic rivets. If necessary, you simply clip out the center part and extend the tow bar - I can send some detailed shots later...
Sure, that would be great! Thank you!
@Sniker Below, I have marked the noses and above the plastic rivets.
