Roquo
Hello everyone,
I have ordered a Cupra Leon ST 150 PS eTSI, delivery hopefully in April 🙏
I have often read that you can control the heating or ventilation via the app and then come to a pre-warmed car. However, I couldn't find out if this feature is exclusively available for the hybrid or also for the mild hybrid.
Basically, I understand that a power source must be available and it used to be hybrid-exclusive. However, since the eTSI now also has a battery, I wonder if it works here as well.
Can anyone of the lucky owners maybe share their experience?
Thank you very much 😊
Hi, I've had the eTSI since August and can say so much:
You can either start the ventilation via the app, which runs for up to 20 minutes - or you get in beforehand.
I mean, the climate was set to 20°, regardless of what I had set during the drive..
So far, I haven't seen any real climate control in the app. In summer, it was good - if you thought about it early enough - to get into a somewhat ventilated car that had been sitting in the blazing sun for the last 3-4 hours...
So ventilation, yes, 100%.
Whether these 20° would be reached in winter if you really push the 20 minutes, I can't say - the car is here in the garage and is thus "offline".. for that, not only the ventilation would need to kick in, but the AC would really have to work.
Maybe someone can test it :)
Thank you for your response, that sounds good 😊
I find winter particularly interesting with regard to frozen and fogged-up windows. If some preliminary work is already done while brushing your teeth, that would be great 😊
There is the option of a heated windshield in the PHEVs, but it's actually not needed. If you set the climate control to 22, then the snowy/frozen windows are clear in 10 minutes. The windshield de-icing only works if it is charging at the same time.
@ekm do you mean the front windscreen with window defrost?
I can turn on ventilation, seat heating, and rear window without being at the charger, without being at the charger. If there is still a way to do this while he is at the charger, then many thanks for the Tipp 🤩👍🏻
No, I meant that one, but there might be a difference here between the pre-facelift and facelift. The pre-facelift also has a smaller battery.
Ich hab seit wenigen Tagen einen Cupra Leon ST VZ 333PS.
In der App finde ich den Punkt „Belüftung“ aber nicht 😔
Wurde die Funktion gestrichen?
Dass es sich dabei um keine Standklimatisierung handelt ist mir klar. Aber ich dachte schon, dass es eine Standlüftung gibt.
Das geht nur beim eTSI und bei den PHEV (quasi nur mit zusätzlichen Energiequelle).
wasn't 12V what was already in the older cars back then?
So 12V, cigarette lighter, isn't really much, my wife's A-Class has a 24V onboard network, which you need at least for start-stop automatic as far as I know, and it also doesn't have the ventilation function.
But hey, I AM A LAYMAN!!!!
eine Mercedes A Klasse hat definitiv 12 Volt....
es sei denn du meinst den Mercedes A ctros...der hat 24 Volt...
und ich starte die Teile mit einem 12 Volt Startgerät, wenn die Batterien mal leer sind...
