Successfully picked up Leon 204 PS 4Drive!
It was briefly a maximum of 4000 rpm, I haven’t revved it any further yet, but tomorrow or sometime soon. I don’t need Launch Control, and to be honest, I don’t want to test it either.
For a few days now, I’ve unfortunately had a slight rattling in the driver’s door or B-pillar when driving over uneven roads. Yesterday, it felt like it got a bit worse. At first, it had to be sudden, somewhat stronger bumps on the road for me to hear anything, but now even smaller irregularities are enough. I suspect a loose clip that was holding the wiring harness, which is now loose and the cables are hitting the interior trim, or something like that.
Anyone else with this kind of problem? The car has only done about 1400 km. I haven’t driven much in the last few days, but the noise is 100% reliably there whenever there are bumps :cautious:.
I’ll have the workshop take a look, but because of the winter season, they have at least a 10-day waiting period for appointments.
It's already good that it can be reproduced. Then you can also demonstrate it to the workshop.
Can you locate the noise even without driving?
For example, does the open driver's door "rattle" a bit back and forth? Or place a foot on the door sill and slightly "rock" the vehicle?
Nothing has fallen out of your jacket or trouser pocket that is now rattling on the rails under the seat?
@Invio1 Check if the noise remains when you touch the "panic handle" at the top of the door.
In my case, it was exactly that, and after pulling it firmly 1-2 times, the noise was gone.
With my very first Seat Leon, it wasn’t even fixed ;)
Also try the seatbelt height adjustment.
@Schmitzibu For me, it was stuck – but it was practically "stuck" to the headliner, as it had never been used before. And that’s what caused the noise...
I had the same on the passenger side.
Good when things can be solved so easily (y)
Panic handle... :D :D :D
@Chris1 I only thought of it because the sun visor in my wife's Focus made exactly the same noise. :ROFLMAO:
:ROFLMAO:
Danke für eure Antworten und Lösungsansätze! Besonders Angefixt und Schmitzibu. Ich werde es morgen mal versuchen, auf die Idee bin ich nicht gekommen, weil es sich wirklich wie von hinter der Türverkleidung anhört. Ich hoffe, einer von euch soll Recht behalten und ich werde morgen berichten!
Also, es scheint wirklich an dem Billigplastik-Griff zu liegen, auch wenn ich mir nocht nich zu 100% sicher bin. Der fühlt sich mega billig an, wiegt nix, wackelt seitlich und verursacht anscheinend leichte Schläge gegen den Dachhimmel. Das Geräusch kam zumindest nicht, als ich ihn festgehalten habe. Allerdings konnte ich das Problem nicht lösen, weil die Geräusche weiterhin da sind, wenn ich ihn nicht festhalte. Was meint ihr kann man hier machen? Ohne zu kleben fällt mir irgendwie nmix ein, bin aber auch nicht wirklich ein Bastler. Vielleicht ganz abnehmen... Zwei Kappen entfernen, die Schrauben dahinter raus, dann sollte das irgendwie gehen.
Tennis racket grip tape?
Replacement with a grip from another model (e.g., Audi)?
There is also a glasses compartment that can be mounted instead of the grip (at least there used to be).
@Invio1 na, das freut mich doch.
Ich habe so einen "Filzstopper" dran geklebt - seitdem ist das Geräusch weg.
Kannst dich entscheiden ob du es an den Dachhimmel oder den Griff klebst. Ich habe zum Probieren erstmal den Griff genommen, stört mich dort auch nicht.
War vorhin auch mein Gedanke, weil mir einfiel, dass ich damals beim Ford Focus das Klappern von der Mittelarmlehne so gelöst habe. Filzgleiter habe ich schon Griffbereit für morgen, für beide Griffe vorne :). Mal sehen! Hoffentlich ist es dann weg.
Leider haben die Filzgleiter nicht ganz geholfen. Muss den Griff wohl doch irgendwie komplett fest machen oder abschrauben :unsure:. Es reicht, wenn der Griff sich etwas nach unten bewegt und schon ist das Geräusch zumindest teilweise noch da. Kann nur noch an den (etwas losen?) Scharnieren liegen; ich höre es, wenn ich den Griff hin und her wippe nur dann etwas leiser.
@Invio1 sieh es positiv: das Problem ist lokalisiert und du kannst effektiv etwas dagegen tun.
Wie wäre es denn, an dieser Stelle und mit dieser Vorarbeit auf den Verkäufer zuzugehen? :)
