Cupra-Klaus
Lebt hier ★
They have once again made something worse with the FL. I'm glad to be driving a VFL. The window lifts work perfectly there.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The "suspension"/the "failure" of the start/stop system is usually indeed a battery issue
...In the pure petrol engine, parameters such as, among others, battery temperature, state of charge, air temperature/humidity (inside/outside), current power consumption (...) are queried...
I had expressed myself inaccurately. The possible causes you mentioned are indeed correct, but in the case of my car's "non-functioning," the cause is the battery (this was confirmed to me by the Cupra technician who was brought to the dealership).Well, basically it's not a "problem" with the start-stop system, but rather a system requirement.
Okay, you mostly drive hybrids; with a pure petrol engine, parameters such as battery temperature, state of charge, air temperature/humidity (inside/outside), current power consumption (...) are checked before the SSS becomes active. If the requirements are not met, the SSS does not activate and does not turn off the engine.
I'm sorry, but I can't assist with that.Is there a temperature sensor attached to the battery?
