Wireless charging of the mobile phone battery/Android Auto
Zsi
Finland
What experiences are there with wireless charging of phones? The symbol for wireless charging in my MJ 2026 Leon ST is mostly red and the phone does not charge when it is in the console. Occasionally it can be white, but after a short time it always turns red again
I used the same phone in my previous car (Seat Leon ST 2021), which probably has the same components for wireless charging of phones. There were no issues with wireless charging or Android Auto there.
Reactions: Zsi
Reactions: Zsi
Lädt es dann?
Reactions: ekm
@Ice-Mark I use HMD Skyline It has the latest Qi2 (equipped with a magnet) and as I mentioned before, it worked perfectly in the Seat Leon 2021. I would think that Qi2 should work since my CUPRA is four years newer than the Seat.
hm, all right, thanks for the info. Otherwise, the only option is to drive to the dealer; from a distance, you can't check much yourself, just look with another phone to see if it does the same thing. If so, it should be easier to reproduce it at the dealer. There are also one or two here in the Forum who had their shell replaced. Maybe you also have a defect or something that wasn't connected properly. Definitely have them check and inspect it.
Qi2 does not matter; the car cannot do that.
The HMD switches off wireless charging due to a heat problem.
I had the same issue. For me, it was actually due to the case. It was also one with MagSafe. Now I use a different one, also with MagSafe, and I have no problems.
Tell us what kind of phone you have and maybe also what kind of case.
For me, it works fine with a Galaxy S21 Ultra and S24 Ultra (with the right case or none at all).
I visited my Cupra dealer and we tested my Android phone in two other Cupra Leon models (MJ 2026). The same results. Then we used his iPhone. Again, the same results. The charger recognises the phone, but after a while the Qi symbol turns red
The common factor here is that both my Android phone and his iPhone have the Qi2 protocol. Since we saw the same problem in three vehicles with different phones, this points to a systematic issue. The problem is most likely with the implementation of the Qi2 protocol in the MIB4 infotainment system. Furthermore, the fact that the same phone works in a car with an older MIB3 system confirms this.
The Qi2 protocol was finalised this summer and obviously the final version has not yet been implemented in the VAG infotainment software. Those with a Qi2 phone (iPhones or some Androids) should complain to the manufacturer so that an update is released to fix this issue. In the meantime, using a USB cable is the only solution for Qi2 phones.
As already mentioned, I would be very surprised if the hardware were even qi2 certified. 15W charging power is also possible with qi(1), and it doesn't output any more than that.
