At 130 km/h, the whole vehicle vibrates.
Loco4
Stammuser ★★
I have noticed from the very beginning that vibrations occur in the steering wheel (or rather the whole vehicle vibrates) between 130 and 150 km/h, which I attributed to poorly balanced wheels. Due to a combination of a certain employee's unreliability at the dealership, my limited time at that moment, and later the issue with the defective windshield, the problem has not yet been addressed. Moreover, I thought it would be resolved anyway once I had my winter wheels on. These are now on, but the problem has actually worsened. Since I have been a customer at the local tire dealer for many years, I rule out that the new winter wheels were not properly balanced. Additionally, there were already vibrations with the original summer wheels, just less severe.
Now the question: What could be the cause? I don't know enough about it. The wheels are securely mounted and, as mentioned, freshly balanced and brand new.
Of course, I will make an appointment with the Cupra dealer, but I would like to hear your assessment of the possible cause. :)
@Loco4
Das können unheimlich viele Dinge sein die das Vibrieren auslösen können.
Unter Last sind das am ehesten folgende Dinge wenn die Bereifung ausgeschlossen wurde :
Gelenkwellen
Kardanwelle
Differential
Radaufhängung
Merkst du die Vibration überall oder eher am Lenkrad oder doch eher am Sitz?
Vibration vor allem am Lenkrad spricht meist für die Vorderachse wohin hingegen Vibrationen im Sitz oft für die Hinterachse sprechen.
Sind halt alles nur Mutmaßungen :(
Danke für deine Rückmeldung.
Im Lenkrad spüre ich es zuerst, aber letztlich vibriert das komplette Fahrzeug. Google hatte dazu grob ausgespuckt, dass es evtl. am Allrad des MQB liegt und es wohl auch bei Formentor und Tiguan solche Probleme gibt.
Don't know... I also have all-wheel drive and everything is quiet for me, even when it's faster.
Could have many causes. Misaligned toe/camber (which can also happen from the factory!), imbalance on the driveshaft,...
Strange that it's worse with winter tyres. You could try swapping the front wheels to the rear to actually narrow down the tyre issue a bit.
Otherwise, the only option left is fault diagnosis at the workshop.
But you didn't have any kerb contact, did you?
Given the symptoms, I would spontaneously suspect the driveshaft—that it wasn’t balanced precisely, or that a balancing weight is missing somewhere, or possibly that there is still a production sticker on it.
No, I didn’t have any curb contact. On Thursday, I’m going to the dealer so they can do a test drive with me. I’m curious to hear what they say about it. Funny enough, the vibrations were really bad in the first few days with the winter tyres, but today on the way to work it was more like “just” how it was with the summer tyres. Somehow it doesn’t make sense to me 🤷‍♂️
Hello everyone
In the end, the solution was the brake discs, which were warped and ultimately cracked. Maybe one of these faults. :unsure:
But then it would only have to occur when braking. :unsure:
No, it was also while driving. I hadn’t understood that at first either.
@Loco4
Hatte ich bei meinem bei der ersten Fahrt (Überführungsfahrt ca. 600Km) auch. Komischerweise nicht immer, mal beim beschleunigen, mal bei bremsen, dann wieder nicht, sehr merkwürdig. Verschiedene Fahrbahnbeläge haben sich unterschiedlich auf die Vibrationen ausgewirkt. Kardanwelle kann ich ausschließen, da nicht vorhanden ;)
Ein Besuch bei Reifen Müller hat ergeben, dass vorne 65g fehlten, man sah auch eindeutig wo das Gewicht mal klebte.
@Bean
War halt sowohl bei den Sommerrädern, als auch jetzt bei den Winterräder das gleiche Problem. Ist auch Streckenunabhängig ab ca, 130 km/h reproduzierbar.
Nach der Probefahrt mit einem Serviceberater, der das Problem bestätigen konnte, sind nun für kommende Woche zwei Tage Werkstatt angesetzt. Mal sehen wie es da weiter geht.
So, Auto ist seit Mittwoch in der Werkstatt. Sollte es Donnerstag zurück bekommen. Niemand hat sich gemeldet.
Habe heute angerufen und die Info bekommen, dass sie nicht finden würden was die Vibrationen verursacht.
Kann man da aber nichtmal wenigstens den Kunden informieren, dass es länger dauert? Echt schlimm heutzutage.
Zumal es in meiner Cupra App so aussieht als wäre das Fahrzeug nicht bewegt worden seit ich es dort abgestellt habe.
Hole mir jetzt Montag einen, laut telefonischer Aussage kostenlosen Leihwagen ab. Hatte diese Woche keinen benötigt.
Mal gespannt wie es weiter geht.
Es ist höchstwahrscheinlich das Radlager. Wird jetzt getauscht und dann nochmal nachgemessen, ob es das war.
Radlager defekt bei einem 4 Monate alten Auto...
Reactions: ekm
Wäre ärgerlich, aber wenn es denn tatsächlich die Ursache ist, wäre das Problem zumindestens schnell und einfach zu beheben.
Hatte ich schon beim Neuwagen direkt nach der Auslieferung. Bei den ersten Kurven direkt festgestellt, ab zurück zum Händler und den Wagen dort gelassen. Einen Tag später war das neue Radlager drin und wir haben dann die Auslieferung quasi nochmal durchgezogen.
Bin jetzt auch mal gespannt auf morgen. Wäre natürlich super, wenn es das dann war. Werde hier updaten. :)
Reactions: ekm
So, I got my car back. With vibrations!!
Supposedly, after changing the wheel bearings, the vibrations would be reduced by 80%, and it must be the aftermarket wheels causing the rest. I’m now supposed to put the original wheels back on and see if the remaining 20% disappear as well.
Yeah, sure, I’ll probably have to do that now to keep things moving, but the vibrations are at least as bad as before. No sign of an 80% reduction.
So unfortunately, this whole thing is going into the next round.
Has anyone in the workshop ever taken a look at the driveshaft?
Or the drive shafts?
Whether it's the wheel, you can find out by balancing it after all, something so silly... :rolleyes:
They probably want to do that only once the aftermarket wheels are off.
He even told me that they balanced the wheels. So they can’t be the cause. It’s really annoying me.
Eieiei... Do you perhaps have another workshop within a reasonable distance as an alternative solution?
Someone once tried to convince me that the engine noises I complained about were coming from the water pump... Then it turned out the timing chain was faulty. Long story, different car. Resolved through a complaint to the board at the time, Dr Diess.
Has the car already been measured?
