Dear CUPRA Community
I need your experience with my Cupra Leon VZ. The car is only three months old, has run 4,300 km, and was properly broken in during the first 500 km. Since a highway braking from about 220 km/h, I have the following problem:
A steering wheel vibration when braking from 140 to 100 km/h with light pedal pressure. The harder the DCC chassis is set (Sport/Cupra mode), the more unfiltered it comes through in the steering wheel.
Thank you for your tips and experiences!
- In dry conditions: The vibration is clearly noticeable. The perforated discs at the front show slight thermal discoloration (bluish), but are visually mirror-smooth.
- In wet conditions/rain: Absolutely nothing! The brake behaves completely calmly, smoothly, and unobtrusively in wet conditions.
- Does anyone know this phenomenon where the drilled brake only vibrates when dry and is completely quiet in wet conditions (water film as a lubricant/damper?)? Is this the typical cementite formation?
- What are the warranty chances with Cupra for thermal distortion at this vehicle age and under 10,000 km despite the slight discoloration?
- Has anyone here ever had their windows replaced under warranty, and did the problem come back afterwards?
