At 130 km/h, the whole vehicle vibrates.
I drive the Cupra Formentor VZ310, and I also have this problem with vibrations on the highway between 118-140 km/h (always varying, of course). I've had it with every tire, whether winter, summer, or all-wheel drive. At the moment, I have all-wheel drive Michelin CrossClimate Sport3 tires; first, the workshop mounted and balanced them. Then I went to a Hunter specialist and had a Road Force balance done. After the first time, it got worse, so I complained and went back to have the Road Force balancing done again. Well... at least it's better than before, but the vibrations are still there. I visited the Cupra workshop just yesterday for a check on the tie rod ends, control arms, ball joints, etc. The workshop did a test drive and said in the end that they found nothing. I feel stupid. I've been driving this car for a year. I'm tired of going back and forth because of this problem. I think I'll just accept it like this. I'll just drive under 117 km/h or over 140 km/h 😁 it's frustrating, yes... I'm curious about the feedback in this Forum.
Yes, I'm at that point too. I'm driving until the lease is up, and then I'll get something outside of VW.
I received my leasing Terramar PHEV on Tuesday afternoon.
Everything was fine until the drive home from the office, where I noticed a vibration in the steering wheel while driving at 120 km/h.
Additionally, the steering wheel is slightly off-center when driving straight.
So far, I have driven a maximum of 140 km/h; the vibration is noticeable between 120-140, but sometimes more and sometimes less.
It is strongest when driving straight, and it is almost gone even with a slight curve.
I now have an appointment for wheel alignment and rebalancing of the tires in the middle of next week.
Let us know how it went. I'm curious about what comes out for you. I have no idea if it's really due to road conditions or if it's a Cupra error. I'm at a loss. I've given up by now.
I had a similar experience with the previous vehicle, the Tarraco; it was resolved after balancing and measuring. I hope it's the same here. I will report back.
My wife and I have already experienced that as well. We picked up a new car, and the steering wheel was completely crooked when driving straight. We returned the car immediately and drove home with our old clunker. It was super embarrassing for the dealership. However, they fixed it, realigned it, and then it was good.
The car has been in the workshop since this morning; they said they would contact me when the car is ready.
So far, no one has reached out, so it looks like nothing will happen today either.
I assume that simply balancing the wheels and aligning the tracking wasn't everything that was found.
Yesterday, I was on the motorway for quite a while, so between 115-135 km/h, it was really vibrating quite a bit; at one point, I saw the entire backrest from the passenger seat wobbling/vibrating.
Otherwise, the car drives well, just not in this speed range.
It remains exciting.
Hello,
I got the vehicle back this afternoon.
All 4 (!!) wheels had to be rebalanced, with each wheel missing between 10 and 20 grams of weights, according to the statement.
The steering angle sensor was recalibrated.
The alignment/camber was measured, and that was apparently okay.
If I were picky, I could complain that the steering wheel is still slightly tilted to the left when driving straight.
But it's not like it was before (although that wasn't dramatic either; I've experienced worse), so I can live with it now.
Otherwise, the Terramar drives just as it should, no wobbling between 110 - 130 km/h, completely smooth.
That's how it should have been from the start.
Hello,
maybe it's time for me to give an update again. After, as previously mentioned, the li+re drive shaft was replaced, it got better (but not completely gone). I also went for a test drive with the dealer, and he felt it. It's sometimes more, sometimes less. However, they still haven't been able to find a final cause. In the meantime, they are talking about whether it might be coming from the transmission itself (which I can't believe). A measurement with some vibration sensors on the vehicle yielded no useful results.
Now there's still a possible "balancing on the vehicle" (electronic fine balancing) to consider, provided we can find a workshop nearby that can still do that, to possibly narrow down the problem to the axle and position. I hope this yields results. Otherwise, it seems we'll have to keep driving until something falls apart...
But apparently, this is a series problem, as there are already quite a few of us who are complaining about it.
I'll keep you updated...
Well, what can I say.
My last message was from the end of August, just over 4 weeks ago.
On that day, I picked up the vehicle from the workshop, and it seemed okay to me at first.
However, over time it has become clear that it is not okay.
The rattling/vibration in the steering wheel is back, sometimes more, sometimes less intense.
It only occurs at speeds over 110/120 km/h and depends on how the highway is laid out.
When going through a slight right curve, it is very noticeable; in a left curve, not at all.
When driving straight, sometimes yes, sometimes no.
(A slight steering movement is enough).
This was reproducible this morning during a test drive on the highway.
I immediately noticed that the steering wheel is still slightly tilted to the left.
But the vehicle also pulls slightly to the right at higher speeds (or again).
Since this morning, it is back in the workshop.
I was confirmed that it is a known issue.
And I was informed that there is a completely new work instruction/list from Cupra detailing what exactly needs to be addressed.
There are apparently about 15 points broken down.
I was already told in advance that the vehicle would need to stay in the workshop for at least 2, preferably 3 days due to the list.
It has been confirmed to me that this is a known issue.
I would be interested to know what the exact remedy is supposed to be if it is known... we have always been told that it is not a known problem, however, it is identical for me except for the crooked steering wheel (which I believe is a separate issue alongside the vibrations and not related to it).
Maybe you could have the 15 points listed and forwarded. I would be interested.
Hello,
I can ask again what the work instruction includes when I pick up the vehicle. According to the workshop, it should be very current. At least that's what I understood. Whether they will specify or provide that to me - I'm curious. It's obviously something internal. But I will ask what exactly was checked and done.
I have the car back, but I haven't driven it much yet to ultimately say anything, but it feels significantly better again.
The car was measured and "set with new values from Cupra" - whatever that means now. Furthermore, the tires were examined more closely this time, and it was found that all 4 (!!) Pirelli tires that were originally fitted had both a height and a lateral runout. During the first workshop visit, all tires were already rebalanced. They didn't pay attention to height and/or lateral runout; they thought it was due to poor balancing.
I now have 4 brand new Goodyear Eagle F1 tires on, and they specifically chose a different brand to rule out getting 4 defective tires again. They seem to assume there is a series/production error with the tires.
Well then, I remain curious when I get on the highway and can drive reasonably well. Today it wasn't possible; there was too much traffic - and when it rains, everyone drives slowly. But I didn't notice any vibration in the steering wheel or pulling to the right anymore. It drove more relaxed.
I have no idea what took 4 days and what was done in detail; my question about it wasn't answered very thoroughly. However, the statement was that there is apparently a completely new work instruction/routine guideline from Cupra for the case of what my vehicle had, detailing what to do/check. It seems not to be an isolated case.
If it's gone in the end, then it's good.
It's just silly when multiple things have been done; you really don't know what it was or if several things overlapped to cause the problem.
So, I've now driven a few kilometers and can say that everything is okay now.
The steering wheel no longer vibrates - at any speed.
The vehicle no longer pulls to the right.
The tire change of all 4 Pirellis due to height/side runout and the alignment "with new values from Cupra" (quote from the workshop) ultimately helped.
Now driving is fun ;)
Great that your problem is solved, and a huge WTF to Pirelli....
Maybe switch to Yokohamas from the factory? :unsure:
Okay, I also have this issue with my winter tyres/wheels, which is why the problem won't be solved for me with a simple tyre swap...
And whether it really was the tyres or if that's just a smokescreen for the actual problem is another question...
Thanks anyway for your input on the topic! :)
Hi,
I really can’t imagine the tactic of obfuscation. They wouldn’t swap out four nearly new tires just for obfuscation.
But I was told it’s a known issue and there are "new" work instructions from Cupra regarding this.
I just looked again at the workshop orders from the two service visits, but they really aren’t very enlightening regarding the work performed. Overall, they weren’t very forthcoming either.
You only have the problem with the crooked steering wheel, right?! I don’t think the tires are responsible for that.
I can only quote what I was told: "the vehicle was set up with new values from Cupra."
That was obviously only possible at the appointment at the beginning of October, not four weeks prior. And even at the second appointment at the beginning of October, it was only then stated that it was a known issue.
