Hook for bag etc. on front seat back
Burns
Hello dear Terramar colleagues,
I have noticed after repeated searches on the web: there is still no reasonable solution to place hooks on the back of the front seats. My previous company car was a Seat Ateca, where there were the well-known headrests anchored in the seat with two chrome metal rods. There, I had a standard hook solution attached and could easily hang my shopping bag, etc. No shopping spread across the back seat, no unsightly mess.
In the Terramar, everything is different, as we know; the seats have more of a shell design - without the usual headrest attachment. So, a commercially available solution unfortunately falls flat. There is only this small triangular recess at about neck height. So far, I have only found a tablet holder on the web that takes advantage of this small recess. However, it looks like a 3D-printed part and according to the description, this holder is only intended for use while stationary - very funny :p Assuming I at least use the anchoring of the tablet holder and attach a hook to it... and now hang my shopping bag (which can certainly weigh 5kg) on it, I will probably regret it in the next second 🙈 .. and for that, nearly 40 euros is too expensive for me.
My question to the community: has anyone of you had the same thought as I have and found or created an adequate solution that could be adopted? This topic should also be of interest for the Tavascan.
Ich denke, für eine individuelle Lösung ist @Milan hier ein guter Ansprechpartner. Da gibt es sogar eine eigene Kategorie selbstgebautes Zubehör im Forum.
Er hat da ganz tolle Halterungen für den Kofferraum im Angebot, da wird ihm ganz sicher auch für dich eine super Lösung einfallen.
Und ja, du hast schon recht, dass die gezeigte Halterung eher keine 5kg halten wird ;)
Dass es nicht während der Fahrt genutzt werden soll, dient sicher nur der Absicherung des Verkäufers.
Ähnliche Situation bei mir:
Für die Hunde hab ich eine Rücksitzmatte, die mit Schnappgurten am Vordersitz befestigt werden sollen.
Habe mir sog. Gear Ties von Nite-Ize besorgt. Das sind gummiummantelte Bindedrähte, die man beliebig formen kann.
Durch das Loch in der Mitte gefädelt und seitlich auf die "Schulter" der Sitzlehne gelegt.
Airbags werden dadurch nicht tangiert.
Von der Firma gibt es auch einen S-Haken, den ich im Kofferraum seitlich durch die Schlitze bei der Beleuchtung gefädelt habe. Dieser Gajen ist super für kleinere Taschen, damit die im Kofferraum nicht rumbollern.
Oha das klingt sowohl optisch als auch technisch unschön o_O
Ich denke, dass im Unfall auch ein gummiummantelter Draht im Nacken wehtut... wenn nicht mehr.
(hätte davon gern ein Bild)
Für den Hund habe ich eine Box auf der Rückbank, die passt geradeso zwischen RüBa und Fahrersitz.
In deinem Fall würde ich mit den Ösen im Dachhimmel arbeiten, die eigentlich für das Gepäcknetz gedacht sind.
Ich mach später mal ein Bild. Das Gear Tie verschwindet in der Ritze unterhalb der Kopfstütze, von vorne gesehen.
Ja, schön geht anders. Praktisch ist es trotzdem und es macht nichts kaputt.
Here are the pictures of the Gear-Ties and the hook in the boot.
Thanks for linking it. @AnDerTheker Theoretically, one/I could print something for that, but unfortunately, the hole in the seat on the Terramar is really awkwardly shaped for it. If it’s supposed to be stable, it would have to be quite a “block”.
Unfortunately, I don’t have a Terramar nearby to measure (something like this definitely requires several attempts) and I also don’t (yet) have a 3D scanner to scan it at a dealership.
I also have concerns about crash safety; I think a sturdy plastic dagger aimed at the spine/skull cavity wouldn’t be helpful in the event of an accident. 🤔
To be honest, I think the nice seats are far too good to be messed about with like that. That just isn’t on – just my opinion. :rolleyes:
Well. The use case sometimes requires something like this.
Meanwhile, another idea:
I have this keychain from Njörd;
If you pulled a leather strap through the hole in this style and fastened it with Velcro, you would have a more visually appealing solution. Hooks from Milan's 3D printer could then be attached to the straps.
That would then fit for Terramar and Tavascan. The seats are the same...
Here is a picture of the leather tag combined with Dinamica:
Well. The use-case sometimes requires something like this.
Alternative idea:
I have this keyring from Njörd;
If you were to thread a leather strap through the hole and connect it with Velcro, you'd have a more visually appealing solution. Hooks from Milan's 3D printer could then be attached to the straps.
That would work for both the Terramar and Tavascan. The seats are the same...
Here's a picture of the leather keyring combined with Dinamica:
Yes, I've also seen those straps on Amazon. At that time, I was still convinced there was a better solution for the triangular cutout.
But I do see that if using this adhesive solution keeps me safer on the road, then that's probably the compromise between aesthetics and functionality.
Thanks for posting, Schmitzibu!
Milan, do you have an industrial sewing machine sitting in your basement that you still need to get to know? Sounds like an adventure 🤠 good luck with that! And maybe you could come up with something here: a hook attachment based on the strap principle posted by Schmitzibu, but highlighting or visually echoing the V-shaped plastic inserts of the seat (directly beneath the cutout). These inserts are available in two colours—one in Cupra copper tones, one in an anthracite shade—just like mine and yours, Schmitzibu (according to the image in your post #9). Perhaps the stripe could be designed to repeat the seat's colours at appropriate points? 🤔 Or is there maybe even a transparent solution? But then it mustn't look unpleasantly glossy—oh man, not an easy task if the appearance is to be right!
